Stihl is German and there is not another chainsaw on the market that comes close.
Have a tree down and need a chain saw; this will only see occassional use so I wanted to buy a used on off CL. I see a bunch in the $50-75 range. What brand will be best given it will be used?
Thx!
Buying a used chainsaw can be problematic. You really need to pull the muffler and inspect the cylinder and piston for scoring. You also need to do a compression test. A used chainsaw is only as good as the care it's received.
"Occassional use" means you'll need to run the saw dry between uses and always use fresh gasoline mix (preferrably non ethanol premium) prior to use. You'll also need to maintain the chain so it's always sharp. A dull chain makes sawdust vs. chips, clogs the filtration and results in a lean condition. (lean = bad!!)
Have you considered renting? Home Depot rents out Makita/Dolmar 6401's which are an excellent saw and ready for immediate use.
If you want to buy used then I'd recommend Stihl professional saws. (not the homeowner saws!!) The Stihl MS260 or MS361 would be a good choice. In Husky I'd recommend the 346SP or 372. Don't get the low end Husky's because they're the same as Poulans. Getting a good used saw will cost you way more then $50-75!!!
+1.
For a homeowner that is occasional use electric is the ONLY way to go.
HD sells a really nice extendable electric pole saw by Remington for $99 last I looked. The saw is a small hand-held saw with a pole adapter. Really a slick unit. You can take the saw out and use it normally or put it in the pole and reach up into treees. I have had mine for 7 years with a LOT of use and it works great....and starts every time.
Tom
Funny story (but buyer beware)...
Some time back I found someone on CL selling a used small arborist model Dolmar for $75.00 dollars which was a very good deal;and he was dead set on that price. Well when I looked that saw over I would have sworn he dropped it from the tallest tree not once but many times and it was leaking oil like drunken sailor taking a midnight piss!
I realize many are telling you some fantastic names but knowing something of the history goes along way in the used chainsaw market. Oh and by the way when I causally mentioned the leaking oil all over the place, the seller told me they all leak like that. Yes they do especially when they have been dropped for the sixteenth time from a high place.![]()
Not to rain down on anyone's parade but where on this green Earth are you going to find a used stihl for $50-75 dollars??? Unless they dropped it from a 120 ft. tree or a truck ran over it; I never see those killer deals.
The last fantastic deal was for a German saw for $75.00 dollars that leaked all over the ground so bad from that guy drop kicking that saw all over the place and he said "OH THEY ALL LEAK LIKE THAT"...
I own a Stihl 026 and 029 and my father owns a Husqvarna 42 and 36. All four are great saws but I prefer the Stihls because of the speed and the easier to use oil and gas cap.
Look around for a good 029 because the pros all bought the 028 and 030. Most homeowners could not wear out an 029 in ten lifetimes.
Stihl hands down.
So having a firepit now and seeing all the down trees in the back of the woods behind our house I think I am going to need a chainsaw to cut them up and use them in our pit...
We live close to houses so I'd prefer a chainsaw that was quiet? Electric isn't an option as it's at least 300-400 feet away from the outlet to our backyard. Battery MIGHT be ok, but still weary about spending that much for a tool that uses it's only battery system.
Thanks,
-Nigel
Get a gas saw, ignore your neighbors. They are used to leaf blowers around here anyway. You are not going to be cutting wood all the time so a bit of noise isnt a big deal
This is the minimum I wear every time:
Safety glasses
Earmuffs
Chaps
Steel toe boots
Gloves, usually (antivibration gloves for me)
Helmet when dropping trees.
Even when not dropping trees, I'll often wear a forestry helmet with metal mesh shield and safety glasses underneath. Just remember to lift the shield before you spit.![]()
Hi everyone ! Im new on forum and think which chainsaw should buy !The trees I am taking down are around 16" -19" in diameter. I want a saw that can be used next year and those that follow for a long time and thus it should be budget is it possible? I want something that will get through the wood reliably, smoothly, and quickly. I'm thinking a saw with a 18" bar, or should I be thing 20"? think about HusqvarnaHusqvarna and Stihl are both top notch! I've only got experience with Husqvarna (I have several machines from this brand) and I won't buy anything else, but you can't go wrong with Stihl either. It's just a matter of preference I guess.
Hi everyone ! Im new on forum and think which chainsaw should buy !The trees I am taking down are around 16" -19" in diameter. I want a saw that can be used next year and those that follow for a long time and thus it should be budget is it possible? I want something that will get through the wood reliably, smoothly, and quickly. I'm thinking a saw with a 18" bar, or should I be thing 20"? After this reviewshttp://jonsguide.org/best-chainsaws-review/ same think about Husqvarna
I plan to go out into the woods elsewhere to get wood in the coming years and to do so with as little fuss as possible, so I look at it as the warmth of my family in the cold weather is very dependent on the chainsaw
