Carroll B
The roof on my front porch comes out from the house 6 feet. The roof is supported by 6 wooden 4x4 columns. The columns are 94 inches tall. The top of the columns support what looks to be a double 2x8 header that is wrapped in aluminum. One of the columns has a small rotten place at the base. I would like to replace all the columns and railing with PVC columns that have a metal pole in the center and they are rated to support 3000 pounds each. My question is can a person with average skills replace the columns? I've installed bathrooms, built sheds, and installed porch railings in the past, installed doors, but never something that supports a section of roof. I assume I would need to jack the roof up 1/8 of an inch to install the new columns and could this be done using a pressure treated 4x4 and a hydraulic bottle jack? I am not sure if the current columns are toe-nailed to the header. The current wooden columns are sitting on metal standoffs that sit on the concrete porch. If the new PVC columns need to be attached to the header how would I do this or is the weight of the roof enough to keep them in place? Should I play it safe and hire a contractor to install the new PVC columns and then I install the new PVC railing?
