would it be better to cut the pipe below the old valve, solder a male threaded coupling on, and just install a straight ball valve going vertically? i could then just use a 90 degree elbow on top of the valve to attach it to the meter?
kinda like this.. my machine is down at work so i can use the paint program haha
And as long as we're throwing around credentials:
Commonwealth of MA, unrestricted construction supervisors license CS-044337
Commonwealth of MA registered home improvement contractor registration 103463
In the trades for over 40 years now and spent a good portion of that working as a remodeler affiliated with a very successful local plumbing/heating/gas fitting company.
And I can read and comprehend questions and answer in a fashion that will lead to the resolution of rather than the creation of a problem.
After reading all the posts it would be simpler to just knock the house down and rebuild rather then fix the leaking valve stem. I now know not to ask how to fix a worn faucet washer. So far 45 posts to fix a small leak. Sure hope some of you do not work on live ordinance.
Let the Lord have mercy, please let this thread fade into oblivion.
Have city shut off water. And replace with new ball valve!
This is the only correct or useful answer in this entire thread. The rest of you can file to the right and pick up your degrees as this weeks' graduating class of armchair plumbers. No one here but Holdover even has a clue as to how that valve really works and what to do to fix it.
First of all thank you very much for all the answers, and I do agree that I THINK I can pull the top nut off without leaking and long as the bottom section of the valve doesn't leak. it appears built that way. Still haven't had time to mess with it. As far as possibly giving me incorrect advice I'm not worried, I always plan on getting wet just in case hahaha.
I do have a question and it'd probably because I've never dealt with plumbing parts like this... why do I need a key to remove the large nut on the left side if I decide to replace it? Can't I just use a wrench?
"It is not a worn faucet washer, you see just goes to show you did not read the post properly."
I read the original post, you did not read my simple answer, which shows I did read it. Your just basically repeating my answer, so read before you make a comment, part of the problem around here, as is repeating someone's answer; cuts down on the embarrassment.
Up above someone mentioned that this valve would be the municipality responsibility. Maybe so in your area but in every city I have worked the city responsibility ends at the main, both water and sewer. Service saddle, corp valve, service line, curb valve/box are always the homeowner responsibility. Give this some thought.... The leaking valve in your house decides to let loose while you are gone for the weekend.... Ruins the floors and some furniture. I know of no where that that is the cities responsibility and no city attorney would let it be.
My house is fed by this 3/4 pipeI'm having a hard time believing that that is to supply valve to your house. It looks like a 90degree 1/2 in stop?
That size is good for a sink or something ....but a whole house ? You have any water pressure in there?
Is it bigger than it looks?
Replace with a full flow ball valve and you might like it.
my apologies if any of you were annoyed at my questions, i've been getting alot of that lately that i never used to get here before.
i can get a Watts brass valve for 10 bucks or a Nibco bronze valve for 20... any preference to brass or bronze? don't know why the price difference is so much, assuming material and one is USA made and one isnt
Well got everything I need... if I cut the nut off directly below the like on the bottom side of the valve I called solder an adapter on. The only 90 degree elbow I could find threaded on both ends was a red cast brass fitting rated at 125 psi... I doubt my home water will reach that high
