I was doing a job on the Sheldon lathe the other day and noticed that even though it is mounted on a 2 1/2 inch thick butcher block style bench (Thats how it came) that there was a bit of flex when cutting, I was not taking a real heavy cut at all about .010 and then noticed it again drilling a Z sized hole in brass.
So here is my plan, bit of a pain since the motor and gearbox are mounted under the table.
The existing base is 34"x65" approx it has a drawer unit under the tail end and the motor and gear box at the head.
I will have a 18"x96" drop of 1" plate left over from a project in a few weeks.
What do you all think of making a base out of 2x2x1/8" tube with a built in chest (I have a 5 drawer CM box that is the perfect size) then use 65" of the 1" as the top then adding a back splash and lip to form a chip tray,
Okay guys punch holes in the plan so I can fix it before any sparks are made.
