I need to fab some simple frames around some glass solar panels. Then from the frame I will weld on some tabs for attachment. I originally thought about just some simple angle iron but dont want any lift or shift and thought maybe it would be best to just cut some C channel.
My local steel supply sells 1 inch C channel but doesnt list the ID. I need 11/16th to fit in there and I am wondering if:
I will need a shim? If so, recommendations?
should I put a bead of silicone around the interior?
I am going to weld two L's or U's and then bolt together in case I need to disassemble.
Dont worry, I am going to have someone else install. I am just trying to cut cost.
