myredracer
I had a custom performance engine for a vintage car built about about 10 years ago by a guy who ran a shop in the US and later sold the business which is now in Europe so I can't ask the original builder or shop anything. A needle bearing was installed in the end of the crankshaft for the (manual) transmission input shaft. These engines normally have a bronze bushing.
Yesterday I tried to install the engine in the car after restoring the car for a couple of years. The shaft would only go part way into the bearing. After much head scratching I realized that the shaft diameter is exactly the same size as the bore in the bearing and it's gotta have some kind of working clearance. The bearing bore is a nominal 12 mm size and the shaft measures 12.00 mm. I'm just not finding a simple answer on google. I've installed lots of ball & tapered roller bearing but never a "straight" through needle/roller bearing and they're a LOT different it seems and can involve some complex math. The best I can figure it requires a class "h5" clearance but that's as far as I can figure it out and don't see how that relates to a shaft diameter.
So how do you determine the preload/clearance/tolerance needed so I know what dia. the shaft needs to be? This bearing normally only rotates on the shaft when the clutch is depressed if that makes any difference. The bearing is a drawn cup "HK 1216.26RS" made by INA. What I need to do is take the shaft into a machine shop and get the end machined down a bit. I cut the threads off an old 12 mm bolt and pushed the unthreaded portion of it which is 11.87 mm dia. into the bearing, and it slides in and rotates nicely but just don't know if that's too tight or too loose.
