needle grease fitting?
PoorOwner
CA
What kind of tip do I need to grease these lift pulleys axles?
I know it's a needle type, but I don't want to get the ones that is far slipping into a ball joint boot.
I saw one with the rubber tip that I think will work. What do you think?
The Lincoln version is over $30!
https://www.amazon.com/dp/B000MCZK9M/?tag=atomicindus08-20
If you have done something similar maintenance, where is the injected grease supposed to exit? there isn't much of space between pulley and framing so I am not sure what to look for.
rlitman
Long Island
You are correct that you do not want the "hypodermic" needle type that goes under a boot.
The needle you want is a metal cone tip. The Lincoln one is under ten bucks:
https://www.amazon.com/dp/B0002SR6XE/?tag=atomicindus08-20
If you're using it with a dedicated grease gun, then you'll want something like that.
Otherwise, I'd get one with a zerk on the back that I could click onto my regular grease gun:
https://www.amazon.com/dp/B0059HJKBY/?tag=atomicindus08-20
Cheapest option for rare use would be something like this:
http://www.homedepot.com/p/Power-Care-Chainsaw-Bar-Tip-Lube-Gun-LG001PC2/202519480
Or, if you prefer the angled style:
https://www.amazon.com/dp/B000FMK7FG/?tag=atomicindus08-20
I own something like this for bicycle lubrication:
https://www.amazon.com/dp/B000BR0Y9Y/?tag=atomicindus08-20
Its nice, because you screw the tube of grease right into it.
