bigredcornhead
- Joined
- Aug 9, 2011
- Messages
- 450
So i am probably going to explain this terribly, and there is probably something in existence already that is more capable, but i had to ask if anyone has anything better than the link below.
I was working on what i will call a capture nut, inside a enclosed portion of fender trying to fix a ground. I couldn't fit my hand or fingers for that matter in to the enclosure tohold the capture nut tight enough to wrench. I had to resort to contortionist and some homemade measure just got me wondering if there any pliers that have a bend back on themselves at more than a 90 degree angle.
Here is a product i saw when googling, but the jaw almost appear too long. Any thoughts suggestions or other sets you all might know of?
cal-vantools.com
Adjustable Jaw Fuel Line Pliers - Cal-Van Tools
Designed to disconnect fuel, EVAP and breather, push style quick connect fittings. Can also be used on some electrical connecters. Features a spring loaded handle with a 2-3/8" maximum jaw spread in the straight position and a 1" maximum spread in the 90 degree position. Backed by a Life time...
