Needle scaler replacement needles
Bellaireroad
Fort Worth
I’m looking at needle scalers. Never used one. Are the needles proprietary to make? If I bought an IR, could I go into HF and buy needles for it? Thanks
Lassen Forge
What are these “needle scalers “ used for? I see them with other pneumatic tools and often wondered what they did? Thanks
De-rusting and paint removal, also needle-peening metal to remove stresses (and to give it a certain finish).
I guess you could order replacements from IR (if it's an IR gun) but we never had to deal with it with ours, as even with daily use with high volume high pressure air what wore out was the seals and valves.
plinker
Northern Wi
I have a Blue point needle scaler, had the heads pop off the needles on a few, Got replacements off a broken Sunex needle scaler.
B_Bimmer
Eastern Iowa
I use them for rust and scale removal, but more regularly for welding and paint prep in corners and other tight areas where the wire brush on the grinder won't fit. An indispensable tool in my mind.
