Neighbor selling their pioneer mini split
PCustoms
VT
Just saw a neighbor post their Pioneer mini split up for sale, 1 year old.
Correct me if I'm wrong, but wouldn't you have to vacuum/recover and then properly recharge the new install?
Price is OK, compared to what they paid last year, but I'm betting once you factor in an HVAC technician it's a waste of money.
PoorUB
Fargo, ND
It depends on how well of a job was done when it was removed. Reclaim the refrigerant, close off the service valves, tape off the lines yo the indoor unit and it should be ok.
Cut the lines off and never seal anything up, no valves closed, no tape over the lines, I wouldn't touch it.
Installing isn't too tough but pressure testing it and getting R410 for a home owner can be difficult unless you have connections. Anyone can buy a vacuum pump and gauges.
P
PCustoms
VT
2 responses and 2 conflicting answers....
PoorUB
Fargo, ND
I am not certain they were conflicting, other than the pump down versus reclaim part. Some mini splits you can not pump down. No idea if the one he is asking about can or not. Different models in the same brand, same year can be different.
Simply said, if it wasn't removed properly I would not touch it.
I have seen guys take a saws all, cut the lines, blow the charge and toss the unit off to the side and never seal it up.
P
PCustoms
VT
"Just saw a neighbor post their Pioneer mini split up for sale, 1 year old."
Why are they selling it ? Noise level ? low efficiency? constant issues? etc. With the previous posted info above, I would not go near it.
She doesn't need it anymore (was for an outbuilding/office) and hasn't been removed yet.
chinboys
I would find a HVAC resource to inspect the system, and get quotes for decommissioning as well as install to see if it makes sense to buy the unit.
Most of the problems with used systems is the biology experiment found on the indoor evaporator wall or ceiling heads. The filters are not cleaned resulting in organic matter being sucked in and stuck on the evaporator coil, or pooling up on the condensate pan.
bonneyman
Desert SW
Good point!
That's the problem with buying used stuff - what you're getting with the "deal". It's why certain things are OK to buy used (books, tools, trinkets, etc.) and other things never buy used (shoes and underwear). Just saying.
A device that circulates thousands of cubic feet of air daily that you and your family will be exposed to requires special cleaning - and then it's still a gamble.
P
PCustoms
VT
Well for $800 and an HVAC tech I would be saving anything over buying new.
PoorUB
Fargo, ND
Personally, a used mini split has little value, maybe $200 if you are certain of the condition, and can install it yourself. If you have to pay an HVAC company to install it, I wouldn't bother. It might turn into an expensive lesson.
When I worked in HVAC, we normally refused to install used equipment. There was always something wrong with it, perhaps minor. Some times we installed a piece of equipment and it wouldn't run and the repair was costly. Then the customer was pointing fingers at us because "it worked when we took it out!" It got to the point it was better just to refuse to do it.
Gila Monster
They're such a cheap unit new anyways, it would have to be basically free for me to want to fool with it. Not worth my time to get a used unit all to save like $400.
