Nest - N72 error - Common Wire
windward
SE Wisconsin
I installed a Nest in the house a few months ago and everything was working fine when the AC was running. Once I turned the heat on, the nest could not keep it's battery charged and I am getting an N72 error. I have an AC Air Handler in the attic and a a two wire boiler in the basement.
After many hours with Nest tech support, they recommended I connect a common from the AC transformer (Not the common on the boiler). Apparenely when you are using two separate systems, it always tried to charge the batteries with the AC side of the Nest. I had an extra wire, so I could easily connect it to the AC common.
Before I plug the Nest back up, does anyone see any issues with the wiring?
Thanks in advance!!
bobdole4u2
dothan, al
How's this boiler thing work? Is it in no way connected to the ac evaporator blower? How does it blow warm air through the house?
W
windward
SE Wisconsin
Boiler is for hydronic baseboards. It is not connected to the air handler.
LS6 Tommy
Northern NJ
X2. Boilers make hot water or steam, not hot air.
Windward's diagram is fine. His setup with baseboard and central AC would be my preferred setup if I had everything my way in my house.
Tommy
