Neutral and Ground on the same Lug in Panel
mobiledynamics
Gotham City
If I'm tight on how many available lugs, can I put from the same circuit, the ground and neutral on the same lug in the panel.
I am aware double stacking neutrals under 1 lug is a no-no.
What about the latter
Aceman
Eastern Oregon
Another way is to combine 2 grounds in one hole, that's standard procedure for most electricians. You may be able to put 3 grounds in one hole if your panel label indicates it's legal.
If that still doesn't get you enough room, then I'd probably add a ground bar like Pattenp said.
NO. Dont combine a neutral with anything else in the same hole.
It can cause issues...just had to fix a panel that was incorrectly done like this.
