I want to install a new 100A panel in my detached garage. I already have 1 1/2" conduit buried.
The garage is located at the opposite end of the house from where my house panel is located. I want to run the feeder from my house panel along the ceiling to a splice box on the inside of the house (about 85 ft.). I would then connect the inside feeder cable to the individual wires that will go thru a 12" block wall to an LB connector, down the conduit and into the garage.
It would look something like this.
House panel->-----(85 ft)---->Inside Splice Box--->(12 inch block wall)--->LB connector ---->(underground 1 1/2" conduit 40ft)-------->Garage Panel 100A
The question are?
What cable type, size and number of conductors do I need inside the house from the panel to the inside splice box where I would connect it to the wire that would then run underground thru the conduit? The inside cable will be attached the the joists along the ceiling in the basement.
What type, size and number of couductors do I need to run in the conduit (from the LB connector to the garage panel)?
Thanks
The question are?
Thanks
