New 4 post lift hydraulic fluid recommendations?
66Caprice
Stanwood, Washington
My Bendpak 4 post uses ATF transmission fluid or 10W light hydraulic fluid.
But if you go to the manufactures web site you should be able to look at the owners manual online. Or google search for it. It will be listed in there.
tdkkart
Eastern Iowa
Mine uses AW32. I wouldn't bother with anything fancy, this is a low use, light duty, low heat application that doesn't need anything more than just a basic oil.
Oilguy
AW32 or AW46. The 32 can be a bit difficult to find as the 46 is pretty much an industrial standard and the 32 is a bit thin for those applications. I have been using 46 in my Atlas for about 4 years simply because it is readily available and I live in a fairly mild climate so the heavier oil will flow fine.
ZipSnafu
Virginia
I have a BendPak and used Dexron in it. It took quite a bit to fill. Make sure you bleed it good.
inane2
Central KY
I have a Challenger E10 two post. I used Dexron III ATF. I see some big temp swings here in KY and it works great.
