webdog
Even with the insulation, in your area, you are undersized. That shop should have had 4 tons. You can contact your local HVAC city or state inspector and they will come out and check it out.
I don't know if you're in a humid climate it's better to have a smaller unit as it will remove more humidity.
I was planning a 5 ton unit in my 2600 sqft addition and the HVAC guy did a load calc and said 3-3.5 is better, our old building that is the same footage of this guys has a 2.5 ton and it right now is cooling both buildings since they are connected and the new HVAC system is not installed yet. So it is cooling with 1600 sqft per ton right now. Sounds like something else is going on... Have you checked the temperature coming out of the vents?
You ideally want the unit to run non stop on the hottest and most humid day of the year.
