sundevil64
Finally after 5 years I am building a shop for my car hobby. I wanted to get some input on lighting and lift placement.
Here are the details:
What do you think of the lift placement?
Thoughts on lighting layout?
Thoughts on electrical layout. Keep in mind this is to get started. I plan on having hose reels for drops for compressed air.
4 post-I want room to get to storage shelves and store larger parts. Looking at Atlas lift as this will mostly for storage of a sub 3000# car.
2 post-I originally had it at the back but moved it forward as I plan on having a ground up project towards the back. This will allow me easier access to the lift. I am looking at either an Atlas, Bendpak, and Rotary revolution lift (all 10k capacity, 220v).
I have allowed space for a temporary engine building room (pvc tent).
The compressor will be outside or in another storage building immediately next to the garage where media blasting will be done.
- 42x35x10 with 4/12 peak height 15.8'
- Metal weld-up building clear span
- 3" insulation vinyl backed
- Slab is 5.5" thick 3000psi concrete with perimeter beams and cross beams 18" deep
- Two 16x8 residential panel doors-manual lift for now
- Two lifts-4 post for storage and 2 post for work
- Primary use storage and work on hobby cars
- 100amp service
- Lighting-t5 8' strips.
- No indoor bathroom. Building will have water outside
- There will be approximately 3-5 cars in this building at any given time
- Eventually I will install a mini split to keep from burning up in the summer. It may be sooner than later given we are in May.
