New build on existing property
Jmonnty
Dowelltown TN
I am building a detached garage (32wx26)
I have a 40x80 pole barn for animals,20x20 shed with 10x9 door for tools and working on snap vehicles.
What should I consider for a parking garage?
BobnCO
32’ is pretty common for a residential 3 car garage; but everyone like more garage space!
Steve W.
Southwest oHIo
If it's strictly for parking, 26' might be deep enough. However, if you plan on having any cabinets or tool carts along the front wall, along with any working room, that can be a bit tight.
Of course, that will depend on whether you are driving a 3500 crew-cab long bed (who isn't :dunno:) or a Smart car, but the 3500 is just a tick over 22' 2" long.
racecougar
Missouri
How many cars do you want to park in said garage? What size cars? Will there be anything else in the garage that you want space for?
mikedodge
If it's strictly for parking sure but why not go bigger cause ultimately you'll almost always end up wanting to use the space for something more. Im always trying to find room to store things like yard tools or tractor implements.
Skyman
Central Maryland
Even for just parking, 32w is too tight for three vehicles. Unless you don’t care about being able to open the door on one vehicle when another is parked next to it.
Stuart in MN
Minneapolis
How many vehicles, and how big are they. Is the space in fact strictly for parking, or will you have other stuff in there and/or use it for servicing. Everyone here rushes to the conclusion you have three long bed double cab dualie trucks, but maybe you only own one Miata.
reader2580
Minneapolis, MN
My passenger car garage is 26 feet deep. There is plenty of room left after I pull my vehicle into the garage. However, I am not driving a big land barge.
Skyman
Central Maryland
Yes, it's very common, at least in this region. And it's what I call a "builder's" three-car garage. The builder can sell it to the buyers as a three-car, and the buyers will be so happy to be buying it. Then, they move in, try to park three cars in there, and realize that for daily living, it just doesn't work well at all. Here's why. This is not a large vehicle:
It's right around 6 feet wide, and has a wingspan of right around 12 feet. This means I can park three of them in a 30-foot wide garage, with almost, or barely, enough room to get the doors open on any one of them at a time, without contacting either a garage wall or an adjacent car, if I'm good enough to be able to place all three of them precisely across the width of the garage. Move the three vehicles six inches farther apart and you'll need 31 feet. Add another six inches of width for clearance to the side walls of the garage, and you're at 32 feet.
This example doesn't allow much in the way of clearances to the sides, and, as noted, it's built around three small-ish vehicles. It also allows for nothing else to occupy space along the side walls. No shelving, workbench, trash cans, bicycles, ladders, lawn mowers, snow throwers, or any of the other myriad things that tend to find their homes in the typical residential garage.
If a staircase intrudes, as is visible in the above photo, the picture worsens.
I would never build a three-car garage that's only 32 feet wide, if it were possible to make it wider. Not if its only intended purpose were to park three cars in it, and certainly not if it were intended that anything else would also reside in that garage. My absolute minimum width for a three-car would be 36 feet.
Ak Jim
Interior AK
When I build my next house it will be 12’ wide per car plus an extra 2 feet on each side. So a 2 car would be 28’ and a 3 car would be 40’.
J
Jmonnty
Dowelltown TN
I poured footers for 26' deep, 32' wide 2 car garage.
Strictly for parking, I have a 20x20 shed for mowers and worrying on stuff, and a 40x80 barn I with a 10x30 bay I used when I rebuilt a 6.0 chevy.
racecougar
Missouri
Back to the OP then, what are you looking for from this thread? Are you asking about framing, wiring, features, lighting, sheeting...?
racecougar
Missouri
If it's honestly just for parking drivers in, and you don't plan to ever do more than that with it, why do much beyond the minimum?
Cairo94507
Auburn, CA
We just completed a 44' wide x 36' deep with a 12.5' ceiling garage. Our goal was to have three cars parked in there with room to open doors and work on them w/o having to move anything. Having 44' is great. We went 36' deep because we did not want to crowd the work bench or be under the open garage doors. We went with electrical outlets at about 6" above bench height all the way around the garage and 6' apart. When installing electrical, don't scrimp on a few extra outlets. We also did 2'x4' LED flat panel ceiling lighting - 48 of them, switched on 4 switches. We set them up 1,2,3,4,7 1,2,3,4, etc. so we could turn on 1 switch and have even lighting throughout and increase lighting as needed. We added an electric car charger for possible future needs. We installed 7 large windows for natural light as well as a 12' dormer with 2 large windows for more natural lighting. We insulated everything and added a stand-alone HVAC for the garage. We have an attached equipment room that houses the tankless water heater, compressor, solar, batteries and Generac electrical components. When we shut the door you can not hear the compressor run. The floor is a 6"-7" 4300 PSI concrete that was power hard trowled for a smooth finish. We sunk a BendPak mid-rise scissor lift into the floor so it is flush to the floor when down- no trip hazard. All the hydraulic lines run in chases in the ground and the motor/pump is in a base cabinet with the control panel mounted on a tall side cabinet in front of the lift area. We are very happy with the end result.
