JDCrae
Morning all. I am in the final planing stages before ordering everything, So i thought it would good to post up the plans, and have people give suggestions etc.
Building size will be 16' x 36' with 8' ceiling height. Walls will be 2x4, 16OC, trusses are wood engineered trusses, 24"OC. Building will eventually be insulated and conditioned but not for at least a year.
Wood construction with skid style foundation so I can have it transported if we ever sell the house.
Walls will be 2x4 standard framed walls, floor will be 2x8 PT joists and supported by 6x6 PT timbers atop a 6inch tamped stone base, framed by 6x6 timbers, 1ft larger than the building.
Tin roofing, T-111 siding, nothing crazy there.
Electrical- Running 240V 100A service to the building via underground conduit. Electricians recommended #4 Aluminum THHX wire for the service. Also planning on running #8 Aluminum 30A circuit back into the main panel from the building. This circuit is for down the road when we get a portable generator to power the basics of the house. Will allow us to safely power those circuits, but not have to have the generator right next to the house etc. We will install the proper interlock of course. Will be running a separate conduit 1 foot above the main line for data cables. Also strongly considering running a 3rd conduit with a jet line for future usage. Conduit is cheap so it seems like a good idea.
Any thoughts or concerns? Like to get independent opinions before I make final calls.
Only question I had was what people would recommend for the subpanel in the building. This is a woodworking shop so there will be some larger tools, but nothing that draws anything insane. No 220 tools at this time, but want to make sure I have that ability. Also plan to do a mini split down the road and those typically require 220 as well.
Thanks all!
Thanks all!
