New CAPRI XL Reversible Flex Head Ratcheting Wrench Set
Fedwrench
Valley of the sun
Capri Tools joined the XL Flex Head Reversible Ratcheting Wrench club with the release of their new wrench set. Although they might be a bit confused because, on the front of their website, Capri refers to their new wrenches as being 120 tooth but, when you dive deeper into the description pages, they're only 90 tooth. I like that they have the socket like extension on the ratcheting boxed end. I also like that they have a real direction switch on top of the ratcheting boxed end instead of a button on the side that I usually bump changing direction when using another brand's wrench. I don't dislike spline but, I'd prefer 12 point. The price. $270 for a five piece set breaks down to $54 per wrench which seems high to me :dunno: They seem to have nice chrome and large, deep size marking in the online photos. :beer:
dnschmidt
Phoenix, AZ
Why would I buy this over ICON? Personally, I don't see any reason to do that. Not when a Harbor Freight store is one mile from my house, is cheaper, has a proven design from KABO and is on Bell Road and Capri is on the other side of the country.
assassin10000
Looks like the same design as Matco has, which another guy has at the shop.
Which have broken more often than the kabo ones I use at the shop.
FigN⋅m
I actually sold my Mountains and snagged the ICONs on sale instead for this very reason.
When these things come out to play, something's going on, so I want local service if there's a snafu.
I just wish there was an effective way of tensioning the pivot to whatever angle I may need to start at.
Callelle
Depew NY
I'd be willing to wait for a sale to try these out to replace my Icons, it would be nice to do away with bumping the direction switch. Capri's warranty is as good as Tekton's and I'm one of the few, it seems, that actually likes the bite of spline drive, so those aren't issues.
bkdc
Look very similar to Matco except that the flex head is held by a pin instead of a screw. I hear the Matco’s break often, and Matco advertises that the head is easily replaced/swapped because of the screw in pin.
At least Capri’s warranty process is reasonable although not as easy as walking into HF for an immediate swap.
sightbike
WA state
Has anybody used these? My hesitation is the spline drive vs 13 point but no one seems to over 12 point in this configuration other than Snap on.
nicks78camaro
Pittsburgh, PA
There needs to be more companies making 21/22 and 24/27mm sizes though. I believe Cornwell is the only one who sells 24/27 instead of the 24/25.
nicks78camaro
Pittsburgh, PA
@nicks78camaro - how do the spline wrenches get stuck? Never owned spline.
Matco sells the 21/22 and 24/27 but they are the same as the Capri.
Every time I remove a fastener I have to bang the wrench on a lift arm for the fastener to pop out of the wrench.
Every time I tighten a fastener I have to wiggle the **** out of the wrench for it to come free of the tightened fastener.
These are the only spline wrenches I own and will likely be the last. The sideways direction switch accidentally switching direction from bumping into adjacent parts is also annoying.
WhataTool
THANK YOU
I never get how other people using these dont mention this at every opportunity. 100% this
Steve_P
Dunno, I have several sets of spline ratcheting wrenches and they work just fine for me on 6 point fasteners, which is all I've ever used them on. This is just one of those GJ things that people here love to complain about, so they have something else to ***** about after screaming "get off my lawn" to the neighbor's kid :ROFLMAO: .
2ndGearRubber
Pittsburgh
Depends what you work on and how rusty it is, as well as fastener quality.
I regularly use reverse on all my torque wrenches, people here say you don't need that for anything but left hand thread. And they forget about torque adapter reach-arounds but I forgive missing that situation. Torque hardware, reverse the torque wrench, then pull back to pop the socket off as it's stuck on the hardware. It partially rotates like it's going to round before fully applying the torque because the fastener is garbage. That's the same method spline seems use use and it frequently means the tools get stuck. Flex wrenches like these, Mountain, etc can be impossible to even get on a fastener because you can't push the floppy head over the corrosion. I'll get the wrench lined up and use a pry bar to push it over the head of the fastener if need be. There will be entire jobs I do where ever single piece of hardware needs to socket rocked back and forth, pushed off with a pry bar, hammered off, etc.
Earlier this week I replaced a wheel bearing on a jeep wrangler as part of doing an axle joint. Hub bolts are 13mm 12 point. I first use a 14mm to knock off the worst of the rust, just slip it on and wiggle it around for the big chunks, then hammer on a 13mm to push off the rest of the rust. Then I beat a 12mm on so I can apply more than 1/4 drive levels of force before it rounds. Then I make the flange on the wheel bearing hub glow orange in ~1 square inch area centered at the bolt threads. One I ended up needing to melt the corner of the hub off as there was no making any progress. These vehicles are annoying with 6 point sockets which is why the paint is always missing on the lift arms right next to the wheel, even the stupid lugs nuts get stuck.
Spline grabs better than 12pt IMO, but there's a cost associated with that. Everything ***** in some way. Flank drive xtra got pushed by snap on as a replacement for regular 6 point sockets yet they're unusable on a lot of hardware without a hammer to install them. 12 point is generally easier to wiggle onto something crusty than spline however the spline will be able to apply more force. But the set is ~1/3 the cost of the 12 point option from snap on, so I keep my spline. It's just an option with pluses and minuses like anything else. I used matco non-slip impacts which are a 6 point spline design for many years, and those stuck to everything. But you basically never rounded anything that wasn't rotten into a cone.
I may pick these up for the reversing lever versus my Mountain wrenches. I preferred the Steelman version but I kept breaking the reverse levers so I got the Mountain. In tight areas pulling off an AC compressor or similar hitting the button on the side is very annoying. Snap on is just hideous with their $800+ price tag. AC season is starting, we'll see how much the side switch pisses me off this year.
nicks78camaro
Pittsburgh, PA
The only other issue I have with Capri is they frequently go out of stock on tools and they disappear from the site completely.
Will these tools or Capri in general be around for years for warranty swaps?
F
Fedwrench
Valley of the sun
Excellent point and with the current trade war/Tariffs' it's anyone's guess.
I have the original Capri long pattern ratcheting wrenches that are no longer made. I also recently picked up their long handled locking 1/4 drive flex head ratchet with an all-metal handle only to have it disappear from Capri's website before I received it :wtf: That was a new record for me :lol:
I've always said a lifetime warranty gives you a lifetime of failed tools. Hopefully, my luck will continue, and I won't have to warranty a Capri tool :beer:
