LopezBart
Finally got our new Woodland Mills WC68 6" chipper assembled, adjusted and hooked up behind our JD 110TLB... got the saw bracket as well to make it easier to manage. I had to cut down the drive shaft, first time to do that but it has worked out just fine. With the hydraulic power feed set in the middle of the speed range, it happily munches its way through 2-3" ocean spray. The red bar in the photo reverses the power feed when pushed - handy when dealing w/ brush that hangs up on the infeed. I've got a bunch of downed willows to deal with down the hill, so we'll try that this fall. It's a solid tool - weighs about 800 lbs. I look forward to chipping the slash from trees rather than saving it until I can burn it in the winter.
Their gear seems solid and well thought out, and easy to assemble and adjust.
