New compressor, any tips for getting it of pallet?
Seabare
Cape Coral, Florida
Well I got it in the garage by myself but now I need to get it off the shipping pallet! Also tips for moving this around so I can get it to it's final location? I have no help!
AA/FC
Leave it on the pallet.... Sort of a buffer between the metal feet and the concrete floor.
Davefr
OR
A few guys and lots of beer afterwords. That's just too top heavy for one person to manhandle or walk off the pallet.
1950mercury
metro detroit
I left mine on the pallet, its been that way for over20 years...its easier to get to the drain too. Leave it on and use a dolly to move
GTA Matt
Zebulon, NC
The pallet mine came on (80 gallon) was pretty much destroyed. I took some things off of the pump so I could hook my engine hoist through the top of it without damaging anything and was able to get it off my car trailer and into the garage with little issue. I did have to use a small ratchet ******** the bottom tied to the hoist to help keep the compressor perfectly vertical.
southalabama
Brewton AL
Series of small blocks.
Inch by inch it's a cinch.
I've done gun safes and compressors.
Though dad left one of his at the shop on a pallet and it has worked well.
AndeiH
texas
i unloaded my 80 gallon quincy by myself using an engine hoist. i'm very lucky i didn't damage the unit or injure myself.
get a couple of people to help or leave it on the pallet, once it starts leaning its very difficult to hold it up.
redmondjp
Redmond, WA
Mine has also been on the pallet for the past 25 years. Use those vibration pads between the pallet and the floor, rocking it to one side and then to the other to set the pads in place. Done.
Lwel9226
So Oregon
Leave it on the pallet.... Rent or borrow a pallet jack to move it around.....
It will also act as an insulator to help cut down some of the operating noise....
I think you will find a hi percentage (70/80%) of larger compressors are still on the pallet they came with......
Lynn W. :thumbup:
Chadwilliam1
Cincinnati
Mine Is a 60 gallon Single stage, So it is not nearly that big. I can tell you It would drive me crazy to leave it on the pallet. Me and my dad man handled mine to get it off the skid and put it on hockey pucks. If you had to you could engine lift the pump off and then pick the tank up. That would lighten it up a bunch but it would add a bunch off work.
C96
Congratulations on purchasing one of the finest USA made compressors :thumbup:
scw1991
when I bought my IR2475 2-stg compressor, to get in the back of my K1500 truck, it took all but 30 minutes to remove the pump and motor. Sure a lot easier to manage removing all that top heavy weight and a hell of a lot safer too.
logical
Northern fringe of the Motor City Suburbs
Drain the tank to make it light first....
If you really want to tackle it alone, build a plywood ramp up to the edge, don't skimp on length or reinforcement and slide/walk it off. You may have to first fill in any gaps in the pallet top to keep it from falling through.... although that happening would accomplish your goal.
I'm with you about not even considering leaving it on the pallet, but do think about some good quality weight rated rubber isolator feet... not hockey pucks... they are too hard.
tdkkart
Eastern Iowa
Fill the garage full of water...
A lot of people around here found out how well compressors float when we had the floods of '08. Only problem is when the water goes away the compressor is usually standing against the wall upside down. The electrical connection keeps it from getting too far away.
Leave it on the pallet, or get hold of an engine hoist.
Davefr
OR
It doesn't look like he has the ceiling clearance for an engine hoist.
I'd take a piece of plywood and nail it to 3 flat 2X4's. I'd slide that new platform next to the pallet and walk the compressor to the new platform. From that platform he could probably walk it to the surface of the garage floor.
A std. pallet is probably around 5" high. I'd shoot for around 2.5" for an intermediate transfer platform.
However I'd still want some backup help to be on standby. That thing looks super top heavy.
fm2176
Down South
Muscle...it's what I've used to move a 550-lb gun safe by myself multiple times, to include up and down stairs. I also used it to load a riding mower by myself without ramps. More recently I loaded and unloaded a heavy file cabinet. Never mind the multiple hernias I've had... :thumbup:
Todd.Brock
Cincinnati
When I got my 80 gallon , it was a low profile pallet. I just walked it off. Probably dumb but it worked. To move it around , looks at a mobile machine base. Mine came from Grizzly. 07d8921f7d536c23c62d5a1589e11cb4.jpgb151b452a4c897d53480477e40572e11.jpg
cagullett1
North Texas
I recently attempted to pull my 60 gallon 5HP on 1 of 3 legs and do a spin maneuver in order to get it off the pallet... needless to say, I wasn't thinking. Luckily I had 2 huge, stiff cardboard boxes nearby that caught the damn thing when I lost balance. Compressor didn't get damaged at all, and my neighbor heard the noise so I had some help to get it back up.
Don't do what I did, use an engine hoist. Hockey pucks have been working out well for vibration dampening. Unless you have a huge shop with a ton of free space, get it off the pallet.
G-force
Oregon
If I had no other option and no help, I might try tethering it to wall studs with straps keeping it in an upright position then try and walk it off onto shorter and shorter blocks until you touch earth. With it tethered it should not be possible to tip on you.
I agree leaving it on the pallet is not what I would do. My Quincy was on a pallet for awhile before it drove me nuts and I ended up anchoring it on rubber pads properly.
eddiemeddiem
Without any difficulty, I was able to disassemble the pallet in place that my 80 gal was on and walk it off in the process.
canuckian
East coast of Canaaada
seems you're able to slide it around so what I'd do (and did) is get it to its permanent spot, use an engine hoist or anything you can find to safely hoist the compressor barely off the pallet, fasten whichever isolator/dampener you choose to the feet and lower it down. I have my own engine lift but you'd be surprised how many people have one that you could borrow if you ask around. There's 3 on my street of only 7 houses. They're pretty cheap to buy as well. I use mine all the time and it's only ever lifted one engine lol.
dkroth
Rochester, New York
If you let me have my choice of the Wiltons I'll come over to your house, remove the compressor from the pallet, place it where you want and even in stall it on anti-vibration pads!
:thumbup:
finn
The UP, God's country
Engine hoists are readily available at almost any tool rental store.
Renting a hoist for a few bucks beats repairing a toppled compressor any day.
CGT80
IE, SoCal, USA
Send it to me. I will find a way to take it off that pallet.
I think you just wanted to show off your new compressor.
YOU ****
That is the compressor I was looking at. I would probably go with the horizontal version as it would be easier to move. Mine would live outside, in a compressor shed.
OK OP, spill the beans.
What size is that monster? I was looking at the 80 gallon horizontal two stage 5hp.
How quiet is it?
RGausman
By Skyline Drive - Virginia
Congratulations, :beer:
Purchased the same SB 735 compressor a year ago. Added an hourmeter and a Wilkerson water separator between the aftercooler and the tank.
Have about 25 hours on it now and no drops of water at the tools. The water separator catches 95% of the moisture and the tank automatic drain takes care of the rest. The temperature of the tubing going into the tank is only about 5 to 10 degrees above ambient while compressor discharge is about 300 degrees.
My compressor is still on the pallet until get the final location for it finished.
You will get greater enjoyment from this compressor. when it is running music to my ears.
Bob G.
quincyqt
at home
I use a cherry picker to move mine.
driftpin
Rent, borrow, or buy an engine hoist.
St. Johns MI manufactured, what did that tall-boy cost you? is it a 5 HP & 80 gallon, single-phase?
It looks pretty. How-many CFM? About 17?
joetech
Iowa
I've never done this so YMMV. My suggestion is to take a sawzall and cut the pallet apart underneath the compressor and then turn the blocks sideways and then walk it off from there.
