so im still undecided on what to do about my motor. but im looking at unloader and check valves, i dont know where they are or if i have them. right now i have the piping that goes to the tank from the compressor and a d squared pressure switch, which has 2 fittings. one is open ( i assume for a gauge), the other has the "thing" that you pull the ring to let air out, what is that. also, on my heads there are 2 plugs, one opens to the exhaust valve, the other to the intake. on some pictures ive seen of my compressor there is a pipe joining each of these ports, what is that? lasty, what spec do you go by for the check valve and unloader valve.
here's my original post http://www.garagejournal.com/forum/showthread.php?t=61969
