New concrete and acid etching
Subisti
Hi, I recently acquired my wife’s old horse barn and have been given the ok to start making it into a garage/man cave. Yesterday I talked to my first concrete contractor and am now feeling I maybe in over my head. I mentioned wanting a vapor barrier and insulation under the slab. I also showed him the picture I hopefully attached and said i would like it to eventually look like it. He said it was acid etched and a quick rundown on how it was done. The pole building is 30x40 he said he would get exact numbers in a day or so but that he thought $8000-8500. He also mentioned the acid etching cost 3-4$ a square foot. At first that didn’t seem to bad but later realized that would be up to 4800$ extra. Do these seem like realistic numbers? Is there anything else that needs to be done after the etching?
Thanks
Matt
BigGarage
Just south of Detroit, MI.
Thanks
Matt
My garage floor is about 20'x30' so only 600 square feet. I used a few gallons of acid when I cleaned and painted the floor 7 or 8 years ago. The acid is less than $10 per gallon right now at Lowes. $4800 would be highway robbery in my opinion. Your floor is twice as large as mine and let's say you even used 3 times the acid I used. You would still only pay for maybe 15 gallons of acid. That's $150 if you used it all. $4800 is crazy.
P.S. Why do you think it needs acid etching?
Dennis
S
Subisti
If you look at the picture I posted he said acid etching is how to get that look. After some searching this morning. It maybe called acid staining instead.
Toolfool
Tallahassee, FL
Look up Kemiko acid stains. I've done a bunch of them. Fairly easy , just follow the instructions to the 'T'. It's a water based acid stain. They have a neutral wash, stain, and clear coat. Do not treat or clean the floor with anything until it has cured and you're ready to stain.
The pic you posted looks splotchy because it might have been acid etched first before staining.
PM me if you need more info.
Ralf11
you can DIY it
also, embed tubing for hydronic heat into the pour - you can thank me later for that...
S
Subisti
Is acid staining much more than cement stain? After watching legacies videos that doesn't seem too bad.
S
Subisti
That was a fantastic article. May I ask why you chose acid stain instead of concrete stain?
RPH
Michigan Thumb
Go to my profile, I posted pics of my acid stain floor. I used 4 different colors. One thing with acid stain is that it reacts with the minerals in the concrete. That will cause variability in the colors. The green I used didn’t react well in some areas but comes through in others. Doesn’t bother me as I wanted some color other than gray. Also mine is a working shop. Spills are going to happen and the random pattern breaks it up. I didn’t know about water based at the time but would be more than willing to try water based. I won’t have gray concrete again. Staining is to easy to do.
rnixon
A conventional stain lays down color with a pigment. Stain that's used on a wooden deck or siding is usually water based , concrete stains are water or acetone based and work the same way, by depositing a colored pigment.
Acid stain actually changes the color of concrete thru a chemical reaction. Metallic salts in the acid react with the lime in concrete and cause the color to change. Copper sulfate creates the blues an greens, Iron creates the reds an browns , other metals an mixtures create the golds, tans, ebony and turquoise colors.
The color of an acid stain is permanent, it won't wear off , it can't be scrubbed off, the only way to remove it is to grind it off
My floor is sealed with, one coat of a one part, Polyurea [SPGX] polyurea is resistant to almost all chemicals and acids , spills just wipe off and there is no hot tire pickup .
Here's a few, more recent pictures of my floor , it's over a year old and I have yet to wash it , just wipe off the spills an sweep up
snorky18
Southeast Tennessee
When we acid stained our basement floor (800SF?) w/ Kemiko it ran ~$0.61/ SF for materials. Labor was pretty intense to get it sufficiently clean, plus the learning curve since it was my first time, but it turned out beautiful.
BigGarage
Did you guys have any concern working with the acid? Seems dangerous
Not related to the topic anymore but when I was using the acid on my floor I had just rinsed the floor with water. I started in the rear right corner and poured a bunch of acid out. A nice big cloud formed and caused me to go outside just to breathe. I did have the roll-up door opened partway but had no idea the cloud would form and choke me. After that I was O.K..
Live and learn.
Dennis
