New concrete - grind, etch or both?
Carnut68
I have a new 1000sqft detached garage with a nice smooth concrete finish. Nothing but foot traffic in there so far. Searching yields mixed results on this question...would you grind, etch or both? My first call to the vendor I think I am going with (mentioned often here) didn't seem to strongly recommend grinding for my application although he did say it generally yields the best results. Their kit also comes with the acid so I would likely do that whether I grind or not I guess. I have to get this done asap...it is absolutely killing me to have this new garage and not put anything in it yet. I have a **** ton of work to do...electric, insulating, interior walls, exterior staining, driveway, etc but all I want to do is start moving in!
Shea
California
Grinding is always the preferred method and does not require acid etching afterwards. Acid etching generally works fine, but sometimes may require grinding afterwards if areas of the slab are particularly hard and not responding as well to the etch. A vendor will rarely recommend that you don't grind unless there is a valid reason not to. A single coat of thinner coating could be an example.
Quality vendors know their product best. We highly recommend following their advice when purchasing product.
Garage Flooring
Grand Junction, CO
Grinding is best when it comes to high solids and medium to high build epoxy. Its best for almost any application when done properly. They key though is if you are using a thin system you have to make sure you use the right grit... This can pose a different issue. Often we have to start with the heavy grit and do a second pass with the finer grit.
Remember a mil is 1/1000th of an inch. So a thin build system can be as thin as 1/500th of an inch -- which will not do that great of a job covering a 25 grit diamabrush floor
Armorpoxy
Etching is fine for many applications, grinding is always better. Please note if you grind you need to use the matching primer a grinding opens up the surface a lot and can lead to uneven porosity and sheen if not primed.
ShakeyPuddin55
Queen Creek, AZ
Subscribing also. My shop is going up in Nov. Thought I read that etching is not recommended for new concrete. I'm trying to keep costs down due to the size of my shop but grinding seems to add a significant labor cost.
Kaizen
New England
If I may hijack with a question on grinding but then no etch.
I just ground mine yesterday and thought I had to etch as well. If I don't etch how do I get the "dust" out? A blower did much but also put it everywhere. the floor looks like it needs a mopping. wouldn't this be a bad foundation for a primer?
