New Construction Garage - Flooring selection help!
Briantj22
I’ve done a decent amount research and am convinced I’m going to cover my floor with more than just a basic sealer but I’m unsure which direction to go...
Here are the facts:
  • New construction attached garage, roughly 950 sq ft
  • It’s a classic 3 car garage, but with a really deep 3rd stall that also had a garage door off of the back for driving my atv or riding lawnmower through - because of this, the garage has a seam/peak down the middle - pitching water forward towards driveway AND towards backwards toward backyard
  • Garage was NOT Power Troweled
  • I live in Wisconsin - temps from -20F to 100F
  • I don’t work on cars beyond oil changes and brakes... if anything, this space will be a spot for me to store my cars, atv, mess with my hunting and fishing stuff, do some minor work, and also entertain (I plan on putting up a tv, possibly building a bar, and insulating, drywalling, and adding some form of heat).
  • Budget - I’m open.
Epoxy: I like the look and price of full flake. The install makes me a bit nervous. So does yellowing.
Polyurea: I like the look, not the price. The install seems doable. I don’t mind the clear polyurea look (like Nohr-s or SPGX) but don’t have enough pictures to make a sound decision on. Plus, this would keep the price down.
Free flow tile: I have no idea what pricing is for these but I like the look and easy install. The idea of road salts and slush sifting through to the bottom in Winter is appealing. Cleaning it out every Spring is not. Also, my seam/peak down the middle of my garage has me concerned these won’t lay well on that.
Porcelain Tile: I won’t do tile due to my lack of experience and the time involved. And I lose all cost savings by hiring it out. Also, I like the look, but have a hard time spending that much money to have someone lay a hard working surface on something I already have... a hard working surface.
Anyway, I know there’s a million different recommendations. I’m just looking for fact checking on my understanding on the various materials, maybe some user input for my climate and conditions, pricing on free flow (also, will it lay OK over a mild peak/hump?), more pictures of clear polyurea installs over non stained concrete, etc.
Really, any help is much appreciated. If I go freefllow, I’d purchase now and install ASAP. If I go epoxy, I don’t think I can install due to temp until Spring, meaning my garage floor will get dirty over winter and most likely have to be etched - something I want to avoid.
Thank you
Brian
Briantj22
Here I've attached an image of my garage layout and dimensions. The dotted red line is where the mild peak is - The garage is pitched towards the front and towards that back garage door.
I really like the idea of Racedeck freeflow because I'm thinking I could install over winter before I move anything in. Budget-wise, I'm think epoxy might be the better option... Plus, I don't even know if Racedeck will work well over that peak.
Brian
Armorpoxy
Hi,
The SPGX clear looks like a standard sealed or polished floor. Here are some pics
wiegs1
I posted a similar thread. I live in Wisconsin and really like the free flow tiles but the winter clean up does not sound like fun. If I go tiles, I will purchase containment mats to keep winter from going under the tiles.
Briantj22
Armorpoxy,
The SPGX is similar to a polyurea product, right? Since my new floor wasn’t power troweled, do I need to grind? Or can I just acid etch? Also, I think it’s too cold in Wisconsin to apply any coatings now. I’m planning on not driving on it until next summer once it’s coated in the spring. Any other recommendations of stuff to keep off of it to reduce the need for grinding?
Thanks!
Brian
James-W
Southeastern Wisconsin
I am not an expert in this by no means, but from everything I have read about it, I am pretty sure you could acid etch if you want to. However, the best way to do it is to grind the floor. It is a lot more work to grind the floor, but you will get better adhesion and that is what you really want.
