New Detached 24X24
lb7landon
This is my first post on the forum but I have been lurking around for months. I love all the helpful ideas that can be found! I just bought my first house. I spent a few months looking around for an older house with a large lot and a decent sized garage as the garage is where I will be spending most of my time. I had little luck finding anything with a house that wasn't a total write off. So I ended up buying a new house in an area with a lane for detached garages. I managed to get the corner lot with one of the biggest lots on the block. The house came with a 20X22 parking pad but that wasn't going to be big enough. I could go to 24X24, any larger and I would have needed to do foundation walls which would mean ripping the old pad out.
I building things myself. I have grown up building things out of steel and with motors, haven't done much construction myself. But I love to learn how to do things and am attempting to build the entire garage myself. Also I am quite young and don't have money to hire out right now. So far it is going very good. Lots of youtube, google, and asking around.
I ended up adding 2' to one side and 4' to the other making it 24X24. I got a permit to have 11.5' walls with a 12/4 roof pitch.
I cored into the existing slab every 16" and epoxied rebar in to hold the slabs together. The entire extension is 6" thick.
I formed and poured an 8" wide stub wall for the garage to sit on. I decided since I am on a pie lot that I would put my garage door facing my yard as opposed to the alley. It took me a while to decide if I did want to do this or not. The benefits were I would have a private driveway and more privacy. The downside was the the slope of the floor would be drastically wrong. There is 3" of slope on the current parking pad that would cause huge pooling against the wall. In the end I decided to do it and pour another pad on top essentially. The re-pour wasn't done until the walls were up.
Stalker photo of the wood showing up.
This photo shows the size of the yard and how the side garage door works.
The walls going up!
One of the main reasons for buying the house was the large yard. We had 7 vehicles in the yard later that night, with a decent amount of space left that will be grass and patio. Eventually I will pour a massive concrete or asphalt driveway.
The walls are so tall! Since I couldn't go as large of foot print as I wanted I will make tons of high storage to keep the floor clean. Everything will be on shelves to maximize space.
I ended up putting a 16X10 door in the garage. Hugely overkill I know. Now I will be able to have the sled deck on my diesel and be able to pull in the garage with the sleds on the sled deck. That could come in handy. Or if I decide to swap the lift on my truck for a custom 16" lift with 40" tires I am set!
My truck fits!
Decided to shingle myself. Researched best methods of roofing for weather in Alberta, Canada. I laid the tar paper and snow and ice membranes Friday and finished half the roof. I came out the next morning and the frost made the tar paper swell and ripple. I read that a leaf blower can solve this so I rented one and went to town. Work fairly well and finished the roof Saturday
Both doors are in. The overhead door is an R18 door. I put the liftmaster 3800 jackshaft lift in. That was well worth the money. I will try and find a picture.
Soffit and Fascia going up. Color and brand matched to the house.
3 pot lights on the wall that faces the house.
Laid more rebar for the re-pour. I dowelled this slab into the existing to help eliminate shifting. This slab is going to be so robust I don't think I will have troubles with major cracking or shifting. 16" O.C. rebar spacing.
Another 6.5 cubic meters of concrete coming in.
It took 18 hrs from start to finish due to low temps (around 7 degrees Celsius). Burnt the concrete with the power trowel and sealed.
Starting to move items in.
That is where I am currently at. Alberta is having a horrible spring so I am waiting to side the garage until the weather comes around. Hopefully within the next two weeks.
55cadillacking
Calgary
I knew that was Alberta within seconds of clicking on your thread! I hope, for your sake and mine, that Spring finally springs at some point. April has been horrendous. Good luck with your build.
Icky1911
Good for you taking on the majority of the build yourself! I consider myself handy but didn't have the "stones" to do my garage on my own. I bet you are learning all kinds of new things. Good luck and congrats on your new garage.
dubber
Canada's Capital
Nice project, man i don't miss those "springs" our has been bad enough to the point of frustrating me beyond belief. Good luck with the rest of your job!
b4z
Great Build! We're not sure if Spring is really here either and we are in South Carolina. It keeps teasing us.
PhantomEB
Medicine Hat, AB, Canuckistan
I so did too, went wow that looks so much like Calgary... .then hey... those trucks dont got front plates..... was scrollin back up to PM you but decided to go down instead and read Alberta hahah!
L
lb7landon
It has been a long time since I have posted anything. I have made lots of progress.
I got the garage wrapped and ready for siding
[/URL]
Picked up all the materials in my 6.5' box using a ladder to support everything.
Progress on the siding. First time doing it, it was pretty easy once the starter strip was on and level.
I planned to lay an asphalt driveway so I decided to put in a small retaining wall to avoid a step slope on the asphalt.
Building the form. Used some plastic to create a round nose
Finished the form and poured some concrete. I dug two footings down about 36" below the bottom of the form to hold it in place. Put some rebar down the footings and tied it into rebar up above.
Stripped the forms off the retaining wall. I wanted to finish that ASAP as I didn't know when I would get the asphalt done. Still had the little bit of siding left to do. I put those two exterior lights on the motion switch mounted at the peek of the garage. This is a very handy feature. Looks better than the typical motion light also. I wired this circuit up so that when the switch inside the garage is "off" the lights turn on with motion. When the switch is on the lights are on with constant power.
Started to trench for power and gas. Decided to dig by hand since we had just got a ton of rain and the soil would be somewhat soft. It was about 40' long and 28" deep to allow for both gas and elec. in the same trench.
I ran 60 amp service to the garage. Used a 6-3 NMWU cable in PVC with 60a service.
I ran the smaller diameter PVC for communication cable. I ended up changing my mind and used it to house wire to complete a 3-way switch. The switch turns on the pot lights on the garage, as well as the back porch light on the house. Lights can be turned on or off inside the garage or house. I absolutely love that.
I made these connections to bring the cable into the house. The home builder cuts a hole in the siding and silicones the box to it. I hate that look and this was pretty easy to do.
The extra room here is for one more electrical outlet that houses the cable for the 3-way switch, and I left room to bring another cable out for a hot tub in the future
Started drywall inside the garage. I was undecided for the longest time if I was going to do drywall or OSB. I finally chose drywall. Partially because it is fire resistant and I will be doing lots of welding and grinding. I do wish I did OSB at times
Insulated and poly'd the walls. I think the insulation was an R-24
Drywall up. Starting mud and tape. This was my first time doing drywall/mud/tape. It was a good project to start on as I plan on finishing my basement later
Painted the walls. Went with a typical two tone with a stripe in the middle. I can't seem to find any pictures of the stripe at this stage
The snow came back. I knew the pad was large and would be a lot to shovel, but it was bigger than I thought. I decided to buy a snowblower to help
L
lb7landon
I missed a few photos for the snow fell.
The only thing I hired out. The asphalt pad. The guys came and removed about 10" of dirt to allow for gravel and asphalt. I was away at work when they did their work which was unfortunate. I had marked out the perimeter I wanted with paint, but by the time they started work the markings were gone. So I had to tell them over the phone which was hard. I had planned on about 4' longer towards the house, and the asphalt is about 2' off the property line with my neighbour. It is still a good size though
I started building a sidewalk from the house to the garage. Walking in the mud got old. I rented a mini hoe for half a day and excavated down about 5"
Building the forms
Concrete poured and finished. Turned out pretty good.
Asphalt and the retaining wall worked our just as I wanted. It helped me avoid a steep slope on the asphalt and looks pretty good I think.
My personal truck and work truck parked at the back of the pad and can still pull two vehicles into the garage and room for parking on the pad. This was my main reason for buying the lot I found. I needed room for parking vehicles and trailers.
I decided I needed some shelving in the garage so I set out building an over head unit
Built another on the opposite wall. Didn't go all the way down because my garage door is offset so it would have been tight getting items in and out. The floor to the bottom of this shelf is 6'-8" so I can still stand with lots of room
I finally got my heater installed
I went with a Calcana 50,000 BTU and have two 10' shields. They stock length of the 50,000BTU unit is 15' but that wouldn't have fit well and I figure I am only making the heater more efficient if anything. My exhaust temps are still warm so the 20' is not too much for this unit
That is where I am at to date! I don't think I have anything major left to do which is nice as I need to finish the yard. It is so nice to finally get my own garage done my way. It is not my 60X100 shop but this will work until that comes.
