Ok I'll try and answer, House built in 1977, large 4300 square feet not a lot of load the 400amps coming in is not totally used. It was on farmland/orchard has two wells with pumps and a outbuilding small barn light and a heater in the winter. I'm looking at 200a in the shop small woodworking shop not a lot of load one or two man operation. So tablesaw 20a, dust collection 20a, planer, band saw ect nothing pulling more than 30amps. Outlets for welder and RV hookup, lighting in the shop and RV space total square footage 3000 sqft. Not heating or cooling at this time.
As above, why would you not simply feed the 200A shop off the 400A 'home' panel?
Perhaps you are stipulating certain things about this project that are causing them to respond with a pretty odd-sounding solution... Who could possibly need 600A?? Unless you are insisting "I want a totally separate 200A service to the shop, I don't want it fed from the house"..and they are saying "OK, this guy is nuts- let's give him what he wants"
Dunno, but something is off here it seems....
REA said since I have 400amp at their meter base, 400 going to house I don't have the capacity to get 200 to the shop. I maybe could redo panel(s) in the house and have one 200amp panel then pull off house for shop.
The other factor was not to have 2 meters since each is charged $58/meter/month.
I have talked with the REA field engineer to get around this with no luck, believe me if I don't need it I don't want to shell out for the equipment.
Doing a load calc for the house is about 180 amps.
Thanks
Another guy down the street had the same issue but his house had 400a going to it with a 200a panel so he was able to run 200 to the shop. Still he was required to install a CT cabinet and two disconnects one for shop and one for house all said and done over $1500 in parts.
Ashamsi:
If I had a grow operation in the basement I wouldn't be worrying about the money for a service upgrade.
Yes local co-op
The guy I mentioned above tried to fight it went to the state Electrical Guru he said there was no need for what the REA was requiring. REA said he's right but that's what we want and you don't put it in we won't hook up our wire.
So I agree with some of the above 400a for the house not really needed but that's what the builder did before me. I could downsize the shop service 100amps maybe. I have had 3 electricians look at with mostly the same outcome. At this point just trying to source equipment.
