New drill suggestions
Rx88
So currently I have the makita lxt hammer drill impact driver set I have had it for several years now and have been happy with it overall no issues with the impact driver. After finishing my last project I could smell the hammer drill starting to burn up a little and also the chuck does not run straight there is some wobble to it also the check will not stay completely tight I have had drill bits flung out of the chuck while using it.
So I'm in the market for a new drill. I have 2 thoughts on this 1 would be to just buy another makita hammer drill. If I did this I would get an additional battery because the bare tool is the same price as one that comes with a battery. the second is to sell my impact driver and 2 batteries junk the old makita hammer drill buy a Milwaukee m18 set with the drill and impact driver 2697-22 which has the hammer drill and the expanded capacity batteries or the compact set drill/driver and impact driver 2691-22.
I have several other corded Milwaukee tools which are outstanding and I was thinking of making the switch
Any thoughts on this? Any one have any experiences with these? How is the capacity of the compact batteries I have heard that they are kind of lacking.
txvwnut
Bedford, Texas
If the M18 stuff is as good as M12 fuel stuff go with Milwaukee. I've got a M12 fuel 1/2" hammer drill, 3/8" right angle drill and 3/8" impact and have been very impressed with all of it.
bmwpowere36m3
Which LXT drill? My first one (part of a $200 kit) wasn't that great and I sent it in for warranty twice for a wobbly chuck and both times the plastic gearbox was replaced. Granted its a cordless drill, so some wobble is "acceptable".
My problem was using it for everything possible and I over-taxed it, but it took it like a champ. I just picked up a XPH07 BL hammer-drill, but its heavy... powerful though (1.25" spade on speed II like a boss)!
What I've found is that most kits regardless of make... usually include low-tier products. So those $100-200 kits, don't expect the highest quality. My new Makita drill and impact set me back $280 (no batteries or charger).
Finally, the hammer portion I've never been impressed with on these cordless drill (maybe only on block/brick). The newer one I picked up has hope at concrete. My next drill will be the subcompact LXT and reserve the big guy for heavy tasks.
R
Rx88
Yea I rarely use the hammer setting it's nice to have though I may have used it 2 times in the last 3 years
The kit I have is the lxt211
gdocktor3
Connecticut
If you're willing to go the Milwaukee route, do it. Either way, buy the brushless drills. I just picked up the Dewalt DCD996B brushless hammer drill and it's bad ***.
sberry
Brethren, Michigan
Buy new with new batteries. I am all for saving money but this is something so widely used having a premium tool is well worth it. I havnt used a corded drill in years.
10 batteries, 5 flashlights. 2 sawzalls. I got 2 impacts but could use 1. 4 drills and I need a couple new as well as a couple lighter for simple screw work.
R
Rx88
I would say stick with the Makita as well. If you have been happy with the tools why change.
While I have been happy with the tools I would like to avoid chuck issues like the one I am having now I don't know if it is something that is common with the makita I have read of a few others with this issue that is the only reason I am thinking of switching
bmwpowere36m3
My newer Makita drill is rock-solid, but its an all-metal chuck (made in Japan) and metal gearbox (more weight and $).
R
Rx88
I'd personally just stick with Makita if you already have the batteries and charger. Maybe upgrade to a higher end drill.
Yea I may be leaning that way maybe just getting a better drill. The battery life on the makita is outstanding and I don't know if Milwaukees can match it. I installed a subfloor and put up all the walls of a medium bathroom and after all that it still lasted me another day of work on 1 battery
R
Rx88
How is the battery life on the m18?
CJM8515
Milwaukee. Buy the heavier duty fuel kit with the hammer/drill. I bought the non fuel kit and the impact driver is fine, but the drill sucked. Not powerful enough. I got the M18 fuel hammer/drill and was WAY happier. Much better and more powerful.
R
Rx88
I just checked out the m18 kit you are talking about feels solid I really like the metal chuck on it. So there is a difference between the m18 and m18 fuel? How is your battery life on those m18s?
CJM8515
The regular M18 is more homeowner based, less overall powerful and of good quality however. The fuel is brushless, much more powerful and designed for contractor heavy duty use. I found that the non fuel drill I had struggled with anything but light tasks. I swapped to the fuel and its like having a corded drill. Battery life is very good with the 4.0 AH batteries. I use my M18 stuff all the time. Impact 3/8 and 1/2, impact driver, drill, and several flashlights. i really like the system and its tools.
Before I had porter cable mid grade stuff, it worked pretty well for what it was but the 2.0AH batteries it came with went quick.
jlipsky14
Northern NJ
Battery life on the m18 is great. I use them every day in construction and with my own projects. I would also say get the fuel, I have both the fuel and non fuel brushed. I have a regular set that I keep in the garage and a fuel set that stays in the truck and goes to work with me.
This is most of it, cant get the picture to rotate properly
