New dry storage shed shipping container?
Demkog
As we all know the hunt for more room is on going, and I have started to wish I had more room. Their are defiantly things that could be in a cold storage for the winter I just want them to be safe and dry. I have a friend that uses a shipping container the only problem is, it is ugly and i don't think i could sell the better half on it, with out making it look better.
I was thinking some thing like this
http://advrider.com/index.php?threads/pole-barn-ideas-suggestions-please.851792/page-2
post 34
put some solar panels onto for battery charging and lights and maybe a vent fan in the summer.
have any of you done a container garage/shed and made them look good. I remember seeing one that was very big on GJ.
kbs2244
A roof with eves will do a lot to change the box shape of a shipping container.
(It will also make it more rain tight.)
Jlarson
We do that on long term construction sites, we paint the containers a light tan and then build a shade cover between them. Doing the same thing but with a nice wood and shingled or metal roof should make it visually acceptable.
Cyberbear
California
A shipping container is a very easy way to obtain needed extra space and a little imagination can make all the difference. Try searching online for examples.
R6 Racer
Northern Ontario Canada
Some pics 4 ya!
I think they're fairly easy to disguise, even cheaper if all you want it for is storage.
The floors will "off gas" ** toxic fumes, & should not be used for plant or food storage or for prolonged stays by living beings (like pets & people)!
**(I think off gassing is the correct term, correct me if I'm wrong & you know)
The floors can be sealed on the inside & all the off gassing will happen outside & underneath. That can be a little costly but they can be made into sweet little guest houses or even better a nice secluded little workshop. If you make it into guest accommodations, don't put in a bathroom. If your guests have to go from one building to another to use the facilities they wont be to tempted to overstay their welcome ;)
You should (I think) do something for the roof. Without something they cam be stupid hot inside on a hot summer day.. Hot enough to ruin some things.
I found a site that gives, what I think, is the best breakdown on container building out there. http://www.tincancabin.com/ Check it out, let me knowwhat you think.
Steve
matt_i
I can see the potential for clashing with a local building inspector, just being non-traditional. That said, a few conversations up front would save a lot of headache later. Attaching the wood framing to the metal structure would be one detail to plan carefully on.
I think the roof would be great, basically a radiant barrier during summer. But I would think also cold in the winter due to metal = fast conduction. Fine for storage, not as good for a working area.
