Garage Flooring
Finally the Perfect Garage Floor Epoxy
Costs: $99.00 / Gallon
Coverage: 250 Sq. Ft / Gallon
Surface Prep: simply clean your floor with a dilution of simple green and water. No need to acid etch or grind.
Welding: No Problem
Chemical Resistance: No markings from automotive fluids @ 24 hours
Cure Time: 1-2 hours
This type of garage floor epoxy would only be available on April 1 AKA April fools day
Some of use who have been around here long enough have seen these types of expectations a lot. Next year we can do a plastic tile that is resistant to welding
In all seriousness there is no perfect garage flooring for all but I am fairly sure there is a perfect garage flooring for you AND you are in the right place. There are a lot of great people here to point you in the right direction.
[In case that was not clear no such product really exists]
Welding: No Problem
This type of garage floor epoxy would only be available on April 1 AKA April fools day In all seriousness there is no perfect garage flooring for all but I am fairly sure there is a perfect garage flooring for you AND you are in the right place. There are a lot of great people here to point you in the right direction.
