New from KS new garage condo under construction
tbauer03
Hello My name is Ted Bauer. I have just moved my family back to my home state of Kansas, previously in Nebraska. My wife and I have bought a house with a 3 car garage and a 19'X30' garage condo.
Ultimately we are looking to use our home garage for 2 cars with a flex bay for house projects, kids toys etc and use the garage condo to support my car hobby. I have 3 what I call never ending projects in a 65 corvette, 92 GMC Typhoon and a 56 chevy 3100. So we have 5 cars total.
I am at the point where I can customize the condo anyway I want in terms of electrical services etc. On paper I have laid out a plan to hold 3 cars using a lift and staggering the cars so one pulls in nose first onto/under the lift and the other backs in So that the drivers door swings open to the middle in both cases. Then I would like to use the inside most corner as a storage area and work space. and leave the front quadrant open for mobility and vehicle access.
Here are pictures of what I have in mind but I would really appreciate feedback on these ideas so that I can adjust before going to far in the build. I am not going to immediately put a lift in until I get a feel for how 2 cars look and feel in the space.
For the building itself this is what was in my head. 100 amp service; (7) 110 outlets. 220 outlet for the compressor and lift. an over head reversible fan,and run a compressed air system through the walls with an outlet on each wall.The one near the garage door will have a 50' reel attached to go anywhere. The outlet over the bench would be to run air tools on projects. and I don't really have a need for the 3rd outlet other than while I am at I might as well in case I want it in the future.
The ceiling is tall. On the garage door side the door itself is 14' tall and I believe the building starts at 20' and slopes up to 30' at the end. Lots of room for loft type storage.
In regards to climate control I am putting in a industrial ceiling fan centered to help cool in the summer and push heat down in the winter. I am going to see how this works using a forced air propane heater on the ground. I am just worried about how well the fan will combat all the heat rising into no man's land.
For lighting I was going to use (4) 8' Led fixtures centered over each quadrant of the garage and use spot lighting else where.
Anyway I have been lurking on this forum for a little while and this is my first official post, I look forward to getting to know everyone.
Thank you in advance for any feedback.
drivesitfar
TB: welcome to GJ first of all and nice first post. are you sure your drawings are dimensional cause it seems like if you have 19 foot wide unit you should have more room on the sides of the cars. just saying.
also i post quite a bit here and i'm also hoping to meet or get to know ALL the members and i maybe know 2% of them so i hope you make your goal.
looks like the move is pretty positive and i like these garage condo options and i don't think they are in our state yet or if they are i haven't seen any.
cheers
T
tbauer03
cheers
Dimensions should be close. I don't have any sort of software designed for this stuff so I just set excel up where the cells were 120pixels x 120pixels to reflect a square foot 12.0 inches x 12.0 inches. Then I ballparked the cars at 15x7 in reality they are closer to 6 feet. Thanks for the response.
revide
Manhattan, KS
Hi. Welcome to GJ! I am pretty new, also. I am just completing my retirement garage in Manhattan, KS. I built it as big as the city would let me, 25' x 40'. I wanted a second floor, but they nixed that.
I am wondering if you might plan on doing welding? If so, you'll probably want another 220v circuit. I installed a 200 amp panel in my garage which includes 220v circuits for: Welder/ plasma cutter, Lift, Compressor, Heat/AC mini-split, and a built-in kitchen oven (I bought at Habitat Restore for $10) to use for drying powder coat.
T
tbauer03
I love Manhattan. My wife and I are ksu alumni.
No plans for a welder. My brother in law has his own shop about ten minutes away set up for welding. My thoughts are if I have the lift and he has the welder we are good between the two of us.
