jlckmj
HI all,
I have read through most of the radiant heat threads on here, and also contacted several heating contractors about installing radiant heat in my new shop.
THE SHOP:
The shop will be 24X36 (864 sq ft) 10 foot 2x6 walls, scissors trusses with a 12 foot ceiling in the middle. Full insulation in the walls, R40 or so in the ceiling, 2 inch foam under the concrete. I have gotten mixed results and information. I am not sure what way to go.
I have been told by two HVAC guys that a water heater will do the job, One contractor said that the tankless water heater will work best, so far all of the contractors have said that in a small shop the boiler is overkill.
My GOAL:
To heat all winter in SE Wisconsin with radiant heat, I do not want the shop at 70 degrees, I would just like the frost out of the floor, with the room temperature at lets say 50 degrees, possibly using a small electric or gas ceiling mount to bring the temp up after opening a door or to raise it quickly if needed.
OPTION:
I have access to a large water heater that is actually a small boiler mounted to a large 70 gallon tank, it was used in a restaurant for a short time before it closed. Evidently a restaurant needs plenty of hot water to keep up with the dish washing needs. One contractor (a plumber) said that this would be too much for the radiant needs in a shop. Any ideas on this set up for radiant heat?
COST:
This is the most critical, I do not want to spend money needlessly, but I also do not want to install something that will not work properly.
Any help on my set up would be greatly appreciated, again I want to do it right, but not spend more than actually needed.
Thanks, Jim
THE SHOP:
My GOAL:
OPTION:
COST:
Thanks, Jim
