New garage build starting soon!
mrramsey
North East Ohio
Well I am getting prepared to start a new build. Needing some additional space to store equipment and my construction trailer. The specs will be a 22'x30' with 10' ceilings, a second floor office, 2x6 walls, insulated 10x9 door, 2 zone mini-split for heating and cooling. Ill post some of my drawings later.
mrramsey
North East Ohio
Here are a few of the prelims.
mrramsey
North East Ohio
Ok so I am not off to a good start keeping this thread updated. I have now gon through several design revisions and settled on building the garage with a mezzanine instead of the full attic second floor. I am also researching lighting. The mounting height for the fixtures will be between 13 and 14’ above the floor. I am considering 4 100w high bay ufo pendants in the main open area.
I’ll post some pics tonight. Having a lot of trouble uploading from my phone.
dcg9381
Austin, TX
Sounds like reasonable compromises. Those UFO high bay lights are the shiznit. I have 5 of them in a 40x60 at 16' up. The light switch is labelled "daylight" because they are bright... Recommend you get some that are dimmer compatible.
mrramsey
North East Ohio
Ok here are some screen shots!
<blockquote class="imgur-embed-pub" lang="en" data-id="a/ckEqahE" ><a href="//imgur.com/a/ckEqahE">Garage</a></blockquote><script async src="//s.imgur.com/min/embed.js" charset="utf-8"></script>
mrramsey
North East Ohio
LOL 'Daylight' gotta love that. I was thinking the same thing about the dimmable fixtures. It makes sense when you just want some general illumination and not daylight.
Craig Balzer
Colorado Springs
I shopped and researched for proper lights for months before committing to these in the high bay of my shop
INTERIOR
MAIN SHOP – 14’ Ceiling
  • 7x HB 150001 50
  • LED: 18” x 30” 150 Watt
  • 18,500 Lumens
  • 5,000° K
  • $150 each
These are dimmable. If you go with LEDs (and dimmable) you'll need specific wire and a specific slider switch. I preferred LED figuring they'll out live me and I'll never need to replace them. And -- I find the lights you are considering to be quite bright and can cause glare.
Attached photo shows lighting at night. Don't mind the mess -- still organizing.
The amount/type of lighting you use needs to be considered with the treatment you put on the walls and floor.
  • My walls are OSB with 2 coats of Kilz primer and 3 coats of Kilz white paint.
  • My floors are epoxied but not with a particularly shiny finish (and with slip resistant particles broadcast across the floor)
nitroracer20
NY
Very noce drawings/renderings - if you dont mind me asking - what did the architect charge? Best of luck - great project
Craig Balzer
Colorado Springs
It's been 2 years since I bought them. I do recall the salesman used a computer program in which he entered the dimensions of my shop. He allowed a foot for the chains attaching the lamps to the ceiling and a work surface of 40" for bench work. IIRC - he came up with 70FC -- that is a very fuzzy number.
Found this on-line. Hope it helps:
Specifications
Input Line Voltage 120-277V
Input Line Frequency (Hz) 50/60HZ
Lumens / Wattage A Package –2 ft: 2600 (20W), 4 ft: 4200 (32W), 8 ft: 8500 (65W)
B Package –4 ft: 2300 (18W), 8 ft: 4900 (38W)
Lumens per Watt (LPW) >130
Color Temperature (CCT) 3500K, 4000K & 5000K
Dimming 0-10V (standard)
Controls Occupancy sensor w/ daylight
harvesting (optional)
Rated Life >50,000 hours
Operating Temperature --20°C to 50°C
CRI 80+
Power Factor >0.9
THD <20%
