hey all, just went under contract on a new place with a 3 car garage.
it has drywall up and mudded everywhere, but looks like no insulation. the electrical and lighting is woefully inadequate. So i'm considering ripping a 1' horizontal stripe in the wall @ outlet level and adding more double gang boxes before i officially move in. based on posts here it looks like every 4' is plenty. do you see anything wrong with this plan for electrical?
while the walls have big holes in them, i'd also like to plum for compressed air lines. what size line should i run through the walls? copper or will PVC work? or maybe a mixture of PVC lines with copper fixtures? anything wrong with running this right under the outlets for power for the main bits and then adding QR wall ports and perhaps vertical drops for a few more drops closer to the floor? i know they must be slightly angled so i can get drains on ballvalves to remove moisture, but any other tricks i need to know?
anything else you wish you did to your garage before you moved in?
