arrowspark
Hi, I'm planning on covering my garage floor with Shield-crete epoxy. I just bought a new house, and will be moving in end of September. The garage floor slab was poured about 3 months ago. I was wondering how I should prep the floor for the epoxy coating. Is it better to acid etch or grind the floor? Right now the floor is smooth. I don't have the tools to grind the concrete but I did buy H&C acid etch solution. The label said the garage floor should feel like 120 grit sand paper after etching. Also when you wash the garage floor do you guys put some sort of protective sheet over teh drywall in the garage to keep it from getting wet?
