New garage floor, need help on proxy
xiaomaizhou
Hello Everybody,
We (living chicago area) are building a new attached garage. Concrete was poured last week. My questions are:1) How long should we wait before applying the proxy? 2) Any brand that you would recomend? Our general contractor suggested Rust-Oleum and it seems to be the low budeget one...how about Sherwin-Williams? there is a SW 2 mins away from my house.
Really appreciate your help!!! :)
Maggie
Garage Flooring
Grand Junction, CO
Hello Everybody,
Maggie
Hi Maggie,
Typically you want to wait 30 days before you apply a coating. I would wait at least that long, but I would also double check with your concrete contractor.
Brands..... I would do a little homework here on Rust-Oleum before you decide to go with it. In general, like everyone they have a range of products, with some being better than others. There have been some people on the forum who have had great luck and others not so much.
If you are going to do an epoxy coating, regardless of what brand you do, preparation is key. Even though the floor is new you still need to grind it or at least acid etch it.
I would look for a high solids product. 90% to 100% solids. For the DIY consumer a little bit of solvents makes the installation easier and more likely to be effective. Consider a primer, base coat and clear coat. You mentioned your GC... Is he putting the product on, or perhaps the painter, or is this something you are undertaking yourself?
There are also other coating systems that are very effective. Everyone has opinions on what is better, and depending on who is installing it and what the garage will be used for, sometimes the answer can be different from one person to another.
If you use a urethane system, the percentage of solids is still important, but the numbers will be lower.
LegacyIndustrial
deerfield, IL
Maggie:
We have (2) very good garage installers in the Chicago area if you want some help with your project. Otherwise, do your research and utilize a primer no matter which way you go.
X
xiaomaizhou
Thank you so much for the info, Justin. They are very helpful.
To answer your question, our GC is going to apply the proxy for us. The garage will be for normal residential usage, but we paln to install a car lift inside. Will that have any impact on the choice of the proxy product or anything else?
Many Thanks.
Maggie
Garage Flooring
Grand Junction, CO
Many Thanks.
Maggie
Maggie,
The decision as to what to use on your floor is critical. The decision will likely impact you every time you enter into the garage for as long as you own the home. There is nothing more frustrating than having spent a lot of time and money investing in your home, just to have have a garage floor that looks terrible every time you pull in.
Depending on where your budget is and the look you are going for, there are really several things you can do. If it is truly just a place to park your car, you could use a combination of a densifier and concrete conditioner. This will protect the floor, be kind to your budget, reduce dusting, increase resistance to abrasion and generally strengthen your floor. It will protect your concrete from the elements and help with stains, BUT it does absolutely nothing for appearance. If this is what you want products like TL37 Concrete Densifier followed by TL40 concrete conditioner would be ideal. You could also use a basic densifier (like TL37) and products from a company called Ghostshield. I spent a lot of time researching them this last week based on a question from another member and if you use the right product they have a very good track record -- but I have never used it myself. Even they will tell you, buy someone else lithium based densifier first for best results
If you want to go with an epoxy product, it is important to use a quality system, to do the prep work and follow the instructions. There are several good products out there. Legacy Industrial and Epoxy Coat have great systems. Obviously I am fond of ours :) Our high solids system gives you the benefits of high solids with just enough solvent to make it easier to install: http://www.garageflooringllc.com/high-solids-garage-floor-epoxy/
Sometimes people use the word epoxy and really they mean they want to coat the floor and make it pretty. We have a urethane system that does that very inexpensively and without the prep work associated with epoxy. You can find some information on that here: http://www.garageflooringllc.com/rust-bullet-concrete/ If I was looking for a good and affordable solution to coat my floor, this is the way I would go. The industrial and commercial testimonials on this product are amazing.
Regardless of if you go with a product from us or a product from someone else, they key is selecting good product and, if it is epoxy PREP PREP PREP. To reiterate, for epoxy: grind or etch the floor. Use a primer. Use something in the 90-100% solids range for epoxy products.
retfr8flyr
Providence Forge, VA
Maggie, I will add my 2¢ and say if your GC isn't experienced with doing epoxy floors, you would be better off getting an experienced installer. The thing with epoxy floors is 1. you need good product. 2. you need to know what you are doing and floor preparation is critical. If the floor isn't prepared properly then you will be having problems in a short time. With your GC recommending Rust-Oleum, it doesn't sound to me like he is very experienced with epoxy. There are many many products far superior to Rust-Oleum. Give Justin or Scotty a call and let them answer your questions.
X
xiaomaizhou
Great, thank you for the detailed info. We will discuss and give you a call if needd. Thanks again.
LegacyIndustrial
deerfield, IL
Use the best material you can. Your labor cost wont be more for better material but it will be too much if your job fails to produce the desired outcome.
