New Garage in Edmonton
Duffman77
Edmonton Alberta
Hello All,
So I have been lurking here for a while and finally decided to post. I bought my home last fall, it has a single car 14'x20' that is very old and only good for keeping the rain off the objects inside, its time is very limited.
My municipality limits my non-attached buildings to 12% of my lot area and my plan is to build up to that limit. Due to my lot dimensions I plan to go with a 22'x40' with the doors on the 22' side. I also want to do approximately 12' walls, this will require neighbourhood approval because I will be over the standard regulation height. I am also leaning towards 2x6 wall on either 16” or 24” centers. I could use some advice on that.
Plans are to do radiant floor at some point (maybe second year if not immediately), power that with a boiler on natural gas. Plans are to insulate the living **** out of this building, using closed cell insulation in the interiors walls, extruded foam on the exterior and cellulose in the ceiling. Windows have not been thought out yet, I want 2 smaller energy efficient windows that open. Doors are to be high R ones without windows. The automotive doors will be high lift style, one will be 9x6 and the other 9x7.
Due to my pad size and dimensions I need to have my concrete engineered, getting my drawing stamped is not the problem, knowing what I need to build is. As per the regulation sheet:
http://www.edmonton.ca/bylaws_licences/detached_garage_application_form.pdf
(If it displays an error, save the pdf and open it from your desktop, it will then work)
So if I stuck to 728 sq ft I could have a simple slab with reinforced edges, it looks like they want me to use a “grade beam pile”. I don’t have a problem that or some of the extra cost, again I am somewhat clueless as to the dimensions. My initial guess is a t-shaped beam with 18” footing and a 6” wall. Depth again is a wildcard, Edmonton Frost depth is apparently 2.3m which is 90.5” or 7.55'. The pad will be heated with in floor so I understand that raises the frost depth but the fact that I am insulating that reduces the effect of heating again. This garage is only going to have 3-4 cars in it and maybe 2 hoists in the future bring the total to 6, the biggest would be an F350, I realize that I need more than a basic 4” slab but how much more do I need that the 12x12” thickened edge slab that is good up to 728 sq ft?
I hope to put a spec up for further scrutiny and some pictures and lot drawings in the next week, any help/advice in the mean time would be appreciated.
joed2323
epping north dakota
Can you even get a f350 in a 9x6 door?? I would go with bigger doors, i suggest bare min 9x8 doors, even this is too small for some
Are you gonna be happy only going 22 feet wide? This seems somewhat tight, could you go 24x38 instead or is the length the most important to you?
If your going radiant floor then your not going to be pouring a floor for 2 years? So just gravel floor for now?
This is going to be a pole barn correct?
D
Duffman77
Edmonton Alberta
I think my F350 isnt bigger than 7' so I could get it in one of the doors and that was may plan to park it only on one side.
My truck is 20' long so I wanted the length to be 2x a typical vehicle, so I feel I am better off with the length than the width, also my lot is not very wide.
I will be putting the pex in with the concrete pour, the heating source may not go in right away, I guess I wasnt clear on that.
Construction will be either 2x4 or 2x6, leaning towards the latter, not sure on the distance between the studs yet.
rburke65
Canfield, Ohio
Well, if you are that far North I would suggest the 2" x 6" walls and for the extra cost go the 16" on center. I had a 10' wide door on a pole barn and it was the reason I went with a 12' wide door on the new shop! Good luck.
Boomer343
Before you get too far along on the details you better determine what is involved with the variance on the height by talking directly with the building dept. You could be in for a long haul to get approvals.
Cobra62
I built myself a new garage here in Edmonton 3 years ago. With my lot size, 22x30 was as big as I could go and be 12%. I now regret not jumping through their hoops and going bigger. When I built mine, the height restriction was 14 feet to the middle of the slope. I used a 4 foot high rafter spanning the 22 feet and got my walls to 12 feet. I have a hoist and it has worked out fine.
I did the 2x6 walls for the extra insulation and that worked out very well too. Not very much more.
I really wish it was a couple of feet deeper though.
PM me if you have any questions.
