New Garage need flooring advise
madmikeee
Building a 29x30 garage. Just had the pad poured and framing will start soon. Since this is a brand new pad I want to get it taken care of ASAP so I don't get any stains or the likes. I have read so many opinions on so many products my head is spinning. I want a durable floor with excellent anti skid qualities. I live in MA so when the winters hit I want the floor to be slip resistant, easily cleaned and durable against salts and solvents.
I know asking for peoples opinions is lighting a fuse LOL but I want the best bang for the buck for a good product. My other question, would it be better for me to do it or just go ahead and hire someone as it is a brand new pad?
thanks for any info provided!! :beer:
Garage Flooring
Grand Junction, CO
A lot of this depends on how the floor will be used:
(1) A simple densifier and sealer like Ghostshield 4500 & 8510
(2) Our simple, plain garage floor epoxy (no flake, tough as nails
(3) Our high end polyurea system. Beautiful flaked floor with outstanding durability and chemical resistance.
madmikeee
it will be used as a garage with some auto work, some wood work etc etc. so It will have to be chemical and salt resistant, anti slip etc.
Garage Flooring
Grand Junction, CO
Either of those options would work well and it really depends on the look you want
Sealer -- No impact on appearance or traction
WB Epoxy -- Generally a solid color. Glass bead added for traction. Incredible chemical resistance
Polyurea -- Hands down the best looking of the 3. Strong chemical resistance and durable.
madmikeee
I am assuming the polyurea is the most expensive as well. :) If I were to go that route with the brand new pad can you give me a run down on how hard/easy it would be to do myself? I read that the polyurea is easier than regular epoxy style floors, with it being a brand new floor what prep would I need to do if any?
Thanks!!!
Garage Flooring
Grand Junction, CO
Thanks!!!
Coatings of any type require attention to detail and some elbow grease. But Polyurea is a very very easy product to work with. You do need to profile your floor. Etch or grind. One of my customers put up this video. Real world what you are looking at
https://www.garageflooringllc.com/2018/06/20/customer-polyurea-install-video/
Jaguar Fan
Park City for Ski Season; Las Vegas for Poker Seas
why would I need to grind a brand new floor?
Laitance is always present on new concrete and must be removed. Laitance is a weak, friable layer on the surface of your new concrete slab which is not well adhered to the underlying aggregate substrate. Most likely, it is the thickness of several sheets of printer paper.
On a brand new concrete slab, an alternative is acid etching. It will eat away the laitance.
If you don't remove the laitance prior to putting down epoxy, everything will be fine... until it isn't. The epoxy is very well adhered to the surface of the slab (laitance) but the laitance itself over time will chip off. :(
https://en.wiktionary.org/wiki/laitance
madmikeee
Thanks for all the info guys! I am thinking I will go with the polyurea. I need a good strong anti-skid surface and from what I am seeing that product is the easiest, although not the cheapest, solution that seems to fit my needs.
Thanks!
madmikeee
Oh one more question, If I choose to have this done by a pro what am I looking at for cost per sq ft (Estimated is fine).
Armorpoxy
Our best 'bang for buck' product is our SPGX one part polyurea. Can be applied with almost no prep, and no mixing and easy application. For clear or a solid color it runs about half the price/sq ft of epoxy. Thousands of satsified GJ users.
madmikeee
Thanks!! I will look into your products as well.
Garage Flooring
Grand Junction, CO
Install prices vary a lot. Also, if you use a pro, personally I would find out what they normally use. They may have a great product and you may get a better deal as a single source
madmikeee
Update, just because, I am STILL not done. My "Friend" , who built my house and I had great faith in, fooked me over hard and I had to hire another framer. He did an EXCELLENT job but is now onto another job he had scheduled. He was kind enough to get his guys in as an emergency and didn't charge me for it. I cannot believe how long this is taking and am beyond pissed off. Could use some motivational speakers here LOL. I am taking over the contracting of the job at this point. WHHEEEEEEEE. I have window and siding guys coming for estimates and then Finalize the inspection after they told me I needed another beam installed, even though the plans were certified a year ago.... Anyone have a beer or 30?
Oh and did I mention I had 2 strokes, heart surgery and my Mother died between August and December?
