Maxtork
Well I wasn't planning on doing my electrical for awhile but the inspector said they wanted to see the electrical stuff when they come out to do the first rough in inspection so I need to knock it out now so I can finish the rest of the garage.. I was planning on doing everything surface mount but if I have to do it now I might as well run it through the walls. So here is my plan and a few questions. Please help point out any areas I am going to have trouble as electrical is not my specialty.
1. I will use a 100 amp breaker from the panel in the house and run power from there through the attic to the corner of the house where it will go into PVC conduit at the soffit. The conduit and feeder wire will run down the exterior wall and into the ground to a 90 street elbow and across to the garage. The garage is about 35 ft from the corner of the house so it is about a 75ft run from house panel to garage panel. I would also like to run a coax cable for TV and a cat 5 cable for internet while I am at it.
What size wire should I use for the feeder?
Can I run the feeder, cat 5 and coax all in the same conduit or might I have trouble with that idea?
I have heard the conduit must be buried at least 18 inches deep which is fine but I have also heard 36 inches deep which seems excessive. I will confirm with the inspector but is 18 inches usually the standard? Also is it normal to run the feeder and cover it back up or do the inspectors usually want to see the trench to confirm the depth?
So then the feeder comes up from the trench to a PVC 90 degree fitting (with the access panel on the back) through the garage wall and up into the 100 amp panel. From the panel I will have two circuits for the outlets spaced around the perimeter of the garage. I will run the 12 gauge cable through holes in the studs to get to each double gang outlet.
Is there a minimum height distance off the floor for the wire runs through the studs? Also is there a minimum height for the outlets in a garage? Any specific size hole for the wire runs through the studs?
I will be using the blue plastic boxes attached to the studs for the outlets and as I understand it I have to have a GFI outlet on each circuit. I will run a 220 circuit for my compressor which will live in the back corner of the garage. I don't have the big compressor yet (I'm living with my 30 gallon 110 unit for now) but I want to have provisions for it when I am ready. I would like to have another 220 outlet at the front of the garage right under the panel for a welder. This way I can plug the welder in and weld just outside the shop if needed.
I will also run two circuits for the overhead lights. I would like to run eight 4 ft fluorescent lights in two rows along the ceiling. I will also have one light outside at the entry door ( I think this is a code requirement) and one outside light on either side of the big garage door. Obviously these will be on switches which I will mount just inside the entry door.
Sorry for the long post and tons of questions. I want to have a good plan together so I don't get too far out of line. I will run all this past the inspector but I want to do it once and not 10 times so I don't become the pain in the *** DIYer and piss them off. Any help, guidance , answers you guys can provide is greatly appreciated.
Max
Max
