From iowa, thanks. My 1930's 16'x16' wood garage has a 3 foot top ridge in center so four sloping faces to center peak. Rafters are full 2x4"s and are spaced about 2 foot on center (varies quite a bit). No heat but use a propane heater when i work out there. And the eaves have a half inch or bigger gap above the walls. I have 30 16"x8'x2" Dow Tuff-R foil on both face's i got for free. Should i cut those to fit between rafters in 16" lifts and leave flush with rafters? Can i block the gaps as i wont heat this more the 4-6 hours a week max. Walls are the same spacing and will work on that next, not sure as the spacing is over 24"s in a lot of places. thanks
