New Guy, same questions
Todasi
Small Town, MI
Hi all, wish I found this website a few months ago when I was working on my house. I am building a new house with a 3-stall garage. This site has already helped me with my flooring options, but like a lot of people, lighting has me confused. In my old garage I screwed in a splitter into the light socket on the ceiling and put two 100w equivalent CFL's.
After reading on here for a while I believe I will buy T8 48". The garage seems SO small after doing this layout (which I found on here).
Here is my garage:
I'm thinking 7 on the third stall (where I'll do most all the work), and 4 on the two stall.
Like this:
Thoughts?
T
Todasi
Small Town, MI
Looks good - you should like the results very much.
What was the Candle/ft power on the 3rd stall btw
Oh well I don't know, that's kinda my question.
(7) T8 32w 48" lights = 14x2500 (lumens)= 336 sq ft / 35000= 104.16 lumens per sqft?
JoeFin
NorCal - where the Rednecks Race
I'm getting numbers in the 55ish range depending on lamp selection
For 1 your not going to get any reflectance off the open wall or the wall space around the tool boxes and bench tops.
If you increase the number of light fixtures in the same space to 8ea you'll see just over 80
Big Bad Pete
You may want to position one light direction over the top of the workbench so that your body doesn't cast a shadow on what you are working on. The other light placement looks good.
T
Todasi
Small Town, MI
Okay, good point Pete about the work bench, didn't think about that.
Joefin, I will have the walls insulated, drywalled and painted semi-gloss light gray...should help a little, although not much. Check out this layout to see if it's a little better.
JoeFin
One of the better layouts I've seen on here. That puts 100 were you need it - under the hood and on the work benches and 80s for the rest of the 3rd bay.
One question - no shelves or upper cabinets above the work benches right ?
2ManyProjects
And you still cussed at it, right?
Here is my garage:
{image deleted}
Like this:
{image deleted}
Thoughts?
Not horrible; but there's room for improvement.
In terms of raw SOURCE lumens, that is essentially correct. But that's not the only consideration (or rather, that's not the end of the story). First, there will be SOME reinforcement from nearby reflective surfaces, as well as some losses at working height due to the distance from the source(s). Because you have a wall on only one side, the "reflective" gain will be somewhat uneven; but I would not panic over this just yet. You have bigger fish to fry.
This one should provide 89.3 lumens/sqft if my calculations are correct.
{image deleted}
I would consider that a step backwards, vis-a-vis your first idea, mostly because you're sort'a "starving" the sides of the vehicle space. If you go back to (at least) three fixtures on each side, it would be better.
At least the workbench itself should have its own dedicated "Task" lighting, the form and precise location of which will depend in part on the details of that workbench and whatever (cabinets, shelving, etc.) may be mounted on the wall immediately above it. Either way, this doesn't really figure in to the GENERAL lighting of the space as a whole.
Having at least one fixture 2-3 feet off the wall in the vicinity of the tool chest is also a good idea; but again, it probably won't have all that much impact on the rest of the lighting plan.
Far more important will be the height of the ceiling, and how it will be finished.
{image deleted}
That appears to be the same thing as your first cut, but with one additional fixture placed over the workbench. As I said above, the workbench task lighting is pretty much a separate stand-alone issue; so the difference is moot.
Here is how I would improve your layout:
-- "Compress" those two three-fixture fore/aft runs on each side of the work bay so that they start closer to the overhead door, and extend only to about the point where the left-hand wall starts (maybe not even quite that far, unless you're willing to go to four fixtures on each side -- which would not be a bad idea in any case). Part of the point is to reduce the end-to-end gaps between each fixture to no more than a foot or so, two at the most. With four fixtures on each side, you could **** them directly together and still cover sixteen feet (plus maybe a foot or two on each end of the runs, due to "spillover").
-- Put at least one fixture (or better, two of them spaced closely together end-to-end) just past where those fore/aft runs end, in order to provide maximum illumination into an open engine compartment, as well as to light up most of the space beyond where the car will actually be parked.
-- Put dedicated task lighting over the ENTIRE workbench. Again, the exact form/placement will depend on the cabinetry, etc.
-- Put one fixture two or three feet off the wall to the right rear of the space, to generously light up the tool chest.
In the "main" (2-car) part of the garage...
-- Turn at least the fixtures closest to the overhead door by 90-degrees, and position them to NOT be blocked by the door when open. The two rear-ward fixtures MIGHT be best left oriented the way they are; but I'm still debating this one.
-- Optionally, put one or two more fixtures running "fore/aft" between the two parking bays. If you add only one fixture, place it JUST beyond where the overhead door sits when open. Also, put in at least two-stage switching for this part of the garage, so that this fixture (or these two fixtures, at most) form your "walk through" lighting, and the rest can be switched on only if/when you want/need brighter light over there.
[Note that a similar "multi-stage" switching system can be used in the third bay; and normally I would beat the drum loudly for both doing so and for using at least three "stages" (including the "walk through" lighting). But in this particular case, it's actually less critical than for most folks, since you will presumably only be using that bay at all when you really have work to do (and will thus want most/all of the lights on anyway). But you still might want to use two stages, with 2-4 fixtures on one switch, and the rest on a second.]
T
Todasi
Small Town, MI
Well, I think I understood everything and made a new drawing. The ceiling will be painted white. I will have two cabinets hung on the wall on either side of the window on the back wall, which I added to the drawing. As for the height of the garage, I'm really not sure, 9.4 ft, whatever standard is, 4" of footing and 9' of framework.
JoeFin
11 in the 3rd bay is a bit of overkill but you surely won't have a lack of light.
Perhaps lose the 1 in the middle of the work area, space the remaining 8 fixtures a little better between the sides of the car and the work bench area and you'll be in the 100 ft/cndls range through out the 3rd bay and work bench area
2ManyProjects
That is a major improvement, IMCO.
Good.
This will have some impact on your task lighting in that area, but not much else. As for that task lighting, some sort of under-cabinet strips would be called for. This is an application where LED makes some sense (in part because they SOMETIMES produce very little heat vs. light; but this can vary from fixture to fixture, so check for yourself), and there are many potentially suitable fixtures to choose from. Use whatever strikes your fancy; but make sure it both puts out plenty of light AND uses plenty of discrete LEDs to do it. I've seen some which use only one super-high-output LED every foot or so, and I don't like them. They not only tend to produce "spotty" light in close quarters, you're SOL if one of those LEDs dies.
That's about what I expected; and it also one of the reasons you're going to wind up needing more lights in there than a simple "lumens/ft.^2" calculation would otherwise imply.
Maybe just a little. But as the saying goes, "Better to have and not need, than to need and not have." And besides, if he sets up the switching correctly, he can handle LOTS of "overkill" without it actually becoming a practical problem.
He could probably "get away with" that; but OTOH, his current plan is pretty good as-is; and that same fixture you're suggesting he drop out would be near-ideal as "walk-through" lighting on that side of the garage.
