jds62f
I can post some pictures up if necessary but I thought I'd start with words and see if someone can help.
I've got a 2.5 car detached garage on a concrete slab with wood construction (siding is aluminum i think). I don't think the previous owner went too far out of his way to do anything, because the bench(es) and cabinets he built were all particle board and sagging pretty badly. Not that there's anything wrong with PB, he just didn't support it appropriately (and apparently he didn't have a level).
Anyway, I've ripped just about everything out of one half of the garage and I'm deciding how I'm going to finish things up. I'm kinda interested in putting up some drywall, but not sure if I need/should put insulation as well. Part of me thinks "its detached, what does it need insulation for?" but the other half of this garage (that I'm not remodeling) has been (kind of) finished, and it sure seems to be warmer in the winter and cooler in the summer.
Anyway, on the unfinished side, the first thing I'm trying to make out is if I have a vapor barrier. How can I tell? I can see the support walls, as they are unfinished. I'm not sure what to make of what I'm looking at though. There is some kind of flat surface between the wood support walls and the exterior siding.... If I didn't know any better I'd say it looks like drywall thats got a foil backing. Imagine you removed the drywall off an interior wall in your home... you'd be looking at the wooden framing and the backside of the drywall on the other side... thats what I'm looking at here, except what I see definitely has a silver metallic sheen to it. There are a couple of small tears and it looks like drywall underneath...
Any ideas? I can post pics later if they would help.
