Highbeam
So I placed the subpanel and am now running some circuits since my panel permit covers 5 circuits as well.
I bought 4 of the 8' 4 bulb t8 fixtures from HD for 40$ each. I bought phillips 4100k tubes with the green ends. Mounted the light and ran the wiring. My ceiling is 14 feet high and it was 25 degrees last night. Fixtures are hardwires with 12 gauge wire on a 20 amp circuit.
When I threw the switch the light turned on but each bulb was pink in the middle and brighter on the ends, as though it was only half way on. No buzz or filcker and all bulbs appeared equally pink in the middle. Like a nice steak. I only ran it for a couple of minutes before I shut it off and checked voltage, reseated the bulbs, hit the fixture a couple of times, etc. Turned it back on and it was a little less pink.
Do these lights/tubes require a break in period? I expected them to fire and get bright. Is my ballast ****? Is this typical of a poor connection? I plan to keep installing the lights so I will be able to test another fixture to see if it is also pink.
Is there some sort of rule against 20 amp lighting circuits?
