balane
I'm at wits end here. Our hot water heater was 12 years old and on its last leg. This morning we had no hot water so I went and bought a new one. Installation was simple and uneventful. It's a 50 gallon tank.
Before connecting electrical I ran water through the tank, with all the hot valves opened up inside the house, for 3 minutes. Pressure is very good.
I know the power lines are connected properly. I tested voltage at both contacts on the upper element and each to ground is getting 122v. The resistance across the element is 15 ohms so I know it's not burnt.
But still, after 2+ hours of sitting the water is ice cold. I opened the pressure valve for a moment and the water is cold coming out of it. The water output line is also cold. I do have the inlet and outlet hoses correctly installed.
Any suggestions here? Thanks.
