MNMike
Hi Guys,
Installed a Hydrosmart panel last weekend and I am having some issues. Below is what I sent to Hydrosmart this morning, I have yet to receive a reply so I thought I would run it by the experts on this forum. The garage is detached 28x32x10 2" foam under slab, R19 walls, R30 ceiling. 4 250' 1/2" loops of Pex 1 zone.
"I was able to get my system put together this weekend but ran into some issues. It is a 1 zone panel with a 115 NG boiler.
The system has been filled and purged, pumps work when plugged in. The thermostat calls for heat and the boiler runs for about 2 minutes and turns off. The thermostat is still calling for heat as indicated by the light ( HS135 ) I can close the Purge T and the boiler will turn on and continue to run. As soon as it hits 100-110 degrees ( set at 120 ) the boiler will shut off and the flow on the controller will go from .8 to .5 then to 0.0. The system will not turn back on although the thermostat calls for heat. I can open and close the purge T and the boiler will turn on and run with the purge T in the closed position. I have adjusted the flow meters on the manifold to .6 GPM and have adjusted the pumps form HI to LOW and all positions in between with no difference in operation.
What am I missing??"
Any help would be appreciated.
Thx,
Mike
Thx,
Mike
