New iron to work on - Delta jointer - table saw combo set-up
xnology
I went out for a short drive and this followed into my car and home.
IMG_2934.jpegIMG_2937.jpegIMG_2938.jpegIMG_2935.jpegI've always dug on the combo machines. Looks like the original base with some mods with the lift and roll bar. I need to get everything back together and see what state everything is in and do an inventory. Pretty stoked and holy **** the motor is gynormous!
WisJim
Menomonie, WI
What you need to make it a complete combo set is the drill press with the hinged mount that attaches to the table saw. It folds down to the side and out of the way when not in use.
X
xnology
I have a shop smith if you're looking. Does your front table adjust on the jointer? If so you have a well-built tool.
Infeed and outfeed are adjustable. It’s a short or standard table 6” delta from the late 40’s I think. That’s what the serial numbers say. The only thing I wish it still had is the rod activated switch for the motor. The motor has no switch currently. Previous owner used it. Said he had the blades sharpened and reinstalled and set to height. I will probably tear it all down and clean everything. Maybe repaint. I will either need to get the correct length stud for the fence adjustment knob or put a spacer in.IMG_2954.jpegIMG_2955.jpegIMG_2956.jpeg
