pb57
This is only my second post since I joined back in July. This is the best forum I've been on! I just wanted to pass on some savings to others in case they were not aware. I just finished up my new shop. This is the second shop I have built. (divorce) This one is 28X34 with 12' sidewalls. Its 2X6 walls with netted and blown in insulation and 5/8 sheet rock throughout. My rural electric co has a program called switch makes sense and if your all electric you get a reduced rate on your heat/air and water heater. My rate is just .04 cents a kw. I installed two 7.5kw heaters in my shop on one thermastat. It costs only .60 cents an hour to heat so it should be very economical in my northern Iowa climate. My house heat/air and water heater is also on the switch makes sense program. I just thought I would post this info since I have never seen this brought up before. thanks for such a great forum. Paul
