new member intro
Red Duck
First post :)
We have a 30 x 60ft shed that is full of tools, equipment, bikes and spare parts for bikes. We park our cars outside all year round. Friends tell me that I'm at "peak shed" in terms of the contents-to-space ratio . . .
My background is automotive machining, and although i have a full-time job, I have accumulated a useful range of machine tools for performing many of the machining operations on cylinder heads, conrods & blocks and producing swarf in abundance. The machine tools are partly for my own vehicles but I also do engines & gearboxes for very patient friends and acquaintances :)
Equipment includes a 1980s Taiwanese Tiger Turn 1340 lathe (similar to Jet, Lantaine, Grizzly etc), ancient Sunnen horizontal hone, equally ancient Van Norman 944S portable boring bar, reasonably modern Kwikway SVS11 valve refacer, Emco FB2 mini mill, and a Scledum RVA 300 S surface grinder (better known in the USA as Storm Vulcan RVA300). Various other odds & ends include a 50 ton hydraulic press, a self-made conrod aligning jig and conrod balancing jig, and a Sunnen AN cylinder hone powered by an antique Wolf 1/2" heavy duty drill that refuses to die.
We have several bikes from classic BMW airheads to more modern Ducati's and a pair of Honda "postie" bikes.
And, we're domiciled in New Zealand :)
nadogail
Coronado, CA
Welcome to the Forum , you have in my opinion almost everything you need to open an engine rebuilding shop. A crankshaft grinder, an Align boring machine and a Hot Tank should make you complete.
The shop I worked in, 1950’s, had Tobin Arp
Equipment, the Crankshaft grinder and Surface Grinder were Surface Grinder were Storm Vulcan.
I am on the Southwestern corner of California.
R
Red Duck
I have acquired equipment over the years by trying not to be impatient, and trying to be ready when they do become available. The surface grinder is a recent purchase that i was actively looking for, but it took two years to find what I wanted at a fair price.
On the other hand, the new 50 ton press was a replacement for my previous press which had leaked for years. The final straw came when assembling a BMW /2 crankshaft which is a press-fit affair with separate bigend pins and full circle conrod bigend bearings & cavities. The force required to assemble it actually bent the frame of the old press . . .
A crankshaft grinder would be a nice-to-have, but conversations with those still in the trade suggest that the days of keeping someone permanently occupied just grinding cranks are over. The shops still grinding cranks are either doing heavy duty diesel work, or they are doing classic and performance work. Either way, it tends to be very intermittent instead of constant now.
I'd still like the tooling to cut recesses for valve seat inserts, better seat cutting equipment, pressure testing gear etc . . . however space is becoming a constraint, which is something I didn't foresee when we built the shed 20+ years ago!
nadogail
Coronado, CA
The Owner of the shop was the principal crankshaft grindef, he hired a member of the Air Force’s who worked partime usually Saturdays, we had popular reground crankshafts in stock waiting for future use, they were sold as exchange shafts.
R
Red Duck
The shops i worked back in the 1980s did the same, and had a crankshaft exchange service for the popular engines of the day. I operated the AMC 1500 crank grinder back then and it was a nice machine to use.
