danum1aaron
Hi everyone. I am in the planning stages of finishing a 1950's unfinished 2 car detached garage and am looking for some wisdom. I’ve read through a ton of posts and gotten a lot of good ideas and thoughts, but I’d like some input. Garage is location in sunny Southern California.
Garage Stats:
20’x18’, 2x4 roof rafters (24” oc), hip roof, no insulation, limited electrical (2x 15 amp circuits), no plumbing
Use(s):
No parked cars, just two motorcycles (rarely used). Used as a hobby garage, working on cars/bikes, occasional woodworking, possible computer desk/cad system eventually, and storage (lots of it).
Current plans:
Electrical: Install 100amp subpanel
Walls: Insulate and hang ½” drywall
Ceiling: (Hard part) With my roof rafters only being 2x4’s, I only have about 3” between the top plate and roof to stick a ceiling joist. With an 18’ span, I know that will not work.
Any advice you all can give me would be appreciated.
What would you do if this was your garage?
Thank you!
Garage Stats:
Use(s):
Current plans:
Option A: Create a 2x8 ledger board, notching the top for the roof rafters to gain a little more ceiling. Install 2x10x18’ ceiling joists at 16” oc on face hangers. This would be an 8’ ceiling.
Option B: Raise the rafter ties/ceiling joists a maximum of 1/3 the way up the roof (15”) and hang the ceiling from the 2x8 or 2x10 @24” oc (attaching the ceiling joists to roof rafters). This option gives me a lot more head space in the garage and makes the area above the ceiling unusable (which is fine). This would be a roughly 10’ ceiling.
Option C: Leave the ceiling open/unfinished.
Thank you!
