So I just installed a new 60A panel in my attached garage. The panel is recessed and I took 3- 1-1/4" conduits up to the attic space for circuit distribution.
However after the fact the first set of receptacles I want to install, see the picture are pretty much right next to the panel but the way I have it now is I would have to run the wire all the way up, then back down and over to the boxes using surface conduit. Can't go behind the wall for this particular wall due to the way the wall is built on that side where it attaches to the house.
Is there any issue if I were to use EMT conduit and come out from the right side of the panel and then transition from inside wall and then just run straight over to the two quad receptacles I have shown in the picture? This would save me probably 40feet of wire... I also plan on putting a 50A welder rec near there also, so I would have this same dilemma and would certainly add cost running that much 8-3 wire..
